Help with default playback issue
  1. Posts : 223
    I usually use my turtle beach for audio. I unplugged it and began using my TV which is connected via HDMI to my computer. When I tried to plug in my turtle beach again It wouldn't show up as the speaker option as it usually does. I am plugging it into The front ports on my computer. The speaker option is enabled and it says it is using Realtek High Definition Audio. It says that the TV is using NVIDIA High Definition Audio. It won't allow me to set the speaker as the default playback device and says my device isn't plugged in even though it is. Please let me know if you need anymore information.
  2. Posts : 1,618
    Win7 Home Premium x64 W10Pro&Home
    you should be able to set the headphones as the default device...
  3. Posts : 223
    Well thats the problem.
  4. Posts : 1,618
    if you have the turtle beach with the transmitter, try pressing the button twice after you plug in, I seem to remember it showed up in devices and then could be selected....
  5. Posts : 223
    I have the x11 so there's no transmitter.
