Sound problem
  1. Posts : 4
    Windows 7 Enterprise x64
    Sound problem
    First let me welcome myself to this forum, My name drew from st. louis (go cards), Problem is when in a chat session , either chatroom , irc or instant messenger, i would like for others to be able to hear my sound such music or anything, on my last system a few years back i install a loop back cable plugged into the line-out on sound card ,with other end going into mic port, this worked perfect, question is , can this be done with out the cable as i have lost it and have no mic,,,If need be i go buy another:
    motherboard is ASUS A8N32-SLI Deluxe 4gigs ram not much on onboard anything, but sound seems ok,
    Audio: Realtek ALC850 8channel
    any idea,??
  2. Posts : 2,111
    Win7 Build 7600 x86
    any idea,??
    Google for "Virtual Audio Cable". 1st link is the homepage
    The latest version is from 2007, so I don't know if it works on Win7.
    good luck
  3. Posts : 4
    Thanks,,
    It installed find but diver wasn't signed so it wouldn't install, so i disabled driver signature in group policy editor, then installed and worked, but i'm not to horny about system ignoring file signature signing, so i just went to wal mart bought a 3 dollar cable. I do appreciate the help though, it was one those liittle problems where you don't lose to much sleep over.. lol..
    BTW on my first post in this forum i posted about free file i found that is best and fastest search for windows 7 there is on the planet, but i didn't realize the thread had a green check mark, so posted it again in the general section,,, well someone deleted it from there, i wasn't trying to cross-post just made a mistake, btw name of the file is searcheverything all one word,,thank you again,, awesome site glad to be a part of it.
    Drew
  4. Posts : 2,111
    Win7 Build 7600 x86
    Drew
    Well, glad you got it fixed so cheap.
    About non signed drivers.
    Generally I would say you're right, but for some small programmer's like the one from "virtual audio cable", getting the drivers signed is just too expensive. (100's if not 1000's of $)
    If you look at the guys site you can see it is an enthusiast at work without commercial motivation.
    You can generally trust those. But it's a personal choice.
    Your fix is easier and more practical.
    Just be careful you don't blow up your mic port with the output signal.
    greetz
