Windows 7: Creative X-Fi Xtreme Audio Driver Problems
15 Oct 2009   #11
I installed the Windows Update driver after I had installed the Driver from (several times).
04 Mar 2010   #12
I have a problem with instal audio console application for x-fi xtreme audio ... I have 5.1 audio home theatre and it works, but I donīt know how to instal the console.I try to install oficial drivers from and it doesnīt work. I want it because now i canīt listen the mp3 in all speakers now, I only hear sound from 2 speakers. In console application it can be set up. I tried instal console application in Win xp and here it works, in win 7 doesnīt. thx for help
Search this Thread:
Advanced Search
Creative X-Fi Xtreme Audio plays no sound
Hi, I installed my soundcard, everything works perfect. I installed drivers and i get no trouble at device manager. After I plug my headphones in and try to play music, i get no sound. At the sound options in windows i see the soundcard and it looks like it works, because the green bar goes up...
Creative X-fi Xtreme Audio
Bought this card today. Because it said support for vista, I thought it would work in Windows 7 as well. Installed the card and I had immediately sound. Then I went to the creative site to install the drivers because I had only control over the volume. There was no EAX, no bass control, nothing....
Sound Blaster X-Fi Xtreme Audio /
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Does anyone know where i can download drivers for this card for the Windows 7 RC1? ive tried the Beta drivers off Creative and had no joy, the ones that came out when the "leaked" RC1 was out and im gettin majorly cheesed off.... ive got everythig else set up how i want except the fact ive no sound...
Creative Soundblaster X-Fi Xtreme Audio
Hello. I'm running Windows 7 build 7600, and seem to have a sound card driver issue. Sound is successfully comming out, but it is screwed up, it fades in and out and has terrible quality (driver from clean install). I am using this sound card, have looked around the forum and have come across a...
Creative X-Fi Xtreme Audio x64
Hello, my Windows 7 x64 (7100) found after a clean install new optional updates which included drivers for my soundblaster X-Fi Xtreme Audio. I also used the drivers I got with the cd and installed them on my system. Everything is working now except a few options. I get sound in 5.1, but when I...
Đ Designer Media Ltd
