Windows 7: Realtek High Definition Audio, No Sound
28 Nov 2012   #11
Shreddie
Windows 7 Home Premium 32bit
Quote   Quote: Originally Posted by ICit2lol View Post
Right Lucas sorry bout that missed seeing your name - mate then you have the software and not a sound card.
So I guess you are using the blue VGA plug for the monitor - see pic sorry about the spelling.
Do you know how to use the Device Manager?
Plus just as matter of pure coincidence I downloaded the RealTek HD centre last night and I had a torrent of malware along with it.
So it begs the question have you scanned recently for malware if not try these
Malwarebytes < free version
and
SUPERAntiSpyware | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware! < free again
Plus what security do you have on the machine mate and how long is it since you last cleaned the machine up?
Try the scans first then it will be a look in the Device Manager - let us know if you are confident with that one - not being funny but you would e surprised how many people are not fully aware of it.
I have Norton Security Suite, I scan at least once a week. The manager came with the drivers, and I'm pretty sure the drivers are official drivers.
also, the wires at the back of my monitor are green (I think that one's the audio cord), white, (I think that is what connects the monitor to the computer to display the pictures) and a black one (for the power). and yes, I am fairly sure that I know how to use the device manager
28 Nov 2012   #12
Shreddie
also, here is a picture of the wires:
http://imgur.com/xLoE2
28 Nov 2012   #13
Sardonicus
Windows 7 Home Premium 64 bit
I would suggest going to the Gigabyte site and use the driver they have posted.
28 Nov 2012   #14
ICIT2LOL
Hum Mack I saw that Lucas had the speakers in the first post what is throwing me is what is failing.
Ok Lucas that was shot of your monitor right? What we need is a pic of the rear of your computer to see what is hooked up there as you say you have a green cable hooked up there but as stated mate the pic is the monitor, I can see no green connection.
Now as I said if you use DVI to the monitor like I said you will not get sound from the monitor speakers the DVI is purely graphical data.
Have a look at the pic I sent it is that panel we need to see with hwatever you have connected.
Let get that sorted first.
28 Nov 2012   #15
Shreddie
currently dling newest drivers; here is the back of my comp
imgur: the simple image sharer
28 Nov 2012   #16
ICIT2LOL
Ok now we might be getting somewhere that is the speaker socket you are plugged into there my friend.
Yes you have the onboard audio and yes it is software driven.
So there is no sound from your speaker set up hooked up like that?
If not can you go to and just check in Device manager the Sound - see my pic.
Just try what I have put in the pic if everything is ok then I know this sounds (no pun) stupid but can you check to see if the speakers or system works on something else it could be something as simple as that.
I am not being funny but are they just speakers and not some powered system?
28 Nov 2012   #17
Shreddie
yes, here is a pic, but it is there, and windows says it is working correctly. when I finish installing the drivers from the official gigabyte site I will update you c:
29 Nov 2012   #18
ICIT2LOL
Ok Lucas now if the Gigabyte drivers don't solve it then this is where you will find the Realtek stuff Realtek
Just one word of caution here - this is what I downloaded last night and it might have been coincidental but I did get a lot of malware afterwards.
So just as a precaution my friend I would strongly recommend you download and install those two anti malware apps I mentioned.
They are always good for everything and just about everyone I know on this site uses and swears by them. Plus they will pick up quite a bit at first of stuff that your Norton may have missed.
Let us know how you go
John
29 Nov 2012   #19
Shreddie
John
drivers didn't work, but I'm gonna install my actual monitor drivers now. I'll update you after
29 Nov 2012   #20
ICIT2LOL
No probs Lucas I wasn't holding my breath on the Giga site ones anyway. I have a Giga in this machine and I know the support is pretty ordinary.
Oh by the way don't forget those malware apps my friend even if it comes up nothing you have lost nothing and there again there may be something - sounds a bit gobbledegook but.....
Microsoft High Definition Driver vs Realtek high definition audio driv
Microsoft High Definition Driver vs Realtek high definition audio driver?
Drivers
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
no sound ,Win7-ultimate x86,realtek high definition audio card
hi i had windows Xp Sp2 for several years and yesterday i have upgraded to Win7. everything went fine except for the sound. i have K9A2 cf-f MSI main-board with on board realtek high definition audio card(i saw the name on device manager it was below of AMD high definition audio device).after...
realtek high definition audio device - no sound
Hi, I just got a new PC and I can't get the sound to work. My PC has the following specs: Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) DirectX Version 11.0 CPU Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz Mainboard Model ...
Realtek High Definition audio no sound after latest update r2.65
Please help...my sound wuz and had been working great for a year now after the purchase bt then i decided to update it to r2.65 yesterday then after the first boot it ddnt work..i have spent almost 5 hours chcking da forums n googling and cannot find a solution to this. Sony Vaio vpcea16fg...
5.1 Sound doesnt work at Realtek High Definition Audio Device
Hello, Some time ago i was tried to connect my 5.1 creative speakers to my laptop and when i wass connecting one by one the cables windows 7 asked me what speakers it will play ( Rear, Front, Center) but now i try to connect them again and it does not ask me that ... and only 2 speakers and sub is...
