Solved Realtek High Definition Audio, No Sound
Shreddie
10:47 PM
Fremont
This is the second time this has happened.
My audio is not working. No output at all. My audio card is motherboard integrated. As said in the title, it is Realtek High Definition Audio (Speakers). Like I also said, this is the second time this has happened. Last time, I reinstalled my drivers and I was good to go. This time, however, I have reinstalled the drivers 3 times to no avail. When I plug in headphones and externals speakers, though, the audio works. Anyone got any suggestions?
Thanks,
Lucas
Windows 7 Home Premium 32bitAMD Athlon 64 X2 Dual Core ~2.9GHz2048MB RAMNVIDIA GeForce 9500 GT
2048MB RAM
Speakers (Realtek High Definition Audio)
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
WinTek English/Chinese Keyboard
Logitech M305
Hello an welcome Shreddie So if they were working what have you done since then? that is different, and where did you download the driver form?
The motherboard too my friend what is that?
1920x1080 D1 & D2 & Laptop 1
Desk1 Samsung 120GB 830 SSD
Asus ROG 256GB 850 Pro SSD
Desk2 Samsung 840 256 SSD
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
The driver is the 6.0.1.6368 driver. I did nothing, I even watched some Youtube videos about an hour before I noticed something was wrong. I got the drivers from Windows driver downloading/grabbing. My motherboard is a Gigabyte GA-MA78GM-S2HP. I also may think that it may have something to do with my monitor's sound system, because if I plug in external speakers to the same plug where I plug in the moniter sound, it still plays.
2048MB RAM
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
Logitech M305
You say that headphones and external speakers work OK. What is not working?
Windows 7 Home Premium 32-Bit - Build 7600 SP1Intel Core i3-2120 3.30GhzKingston 4 GB DDR3 1333 mhzAMD Radeon HD6670
AMD Radeon HD6670
Asus VE228
1440 X 900
Corsair CX600M == 600 Watt
Three 120 mm Fans
Microsoft Natural 4000
Microsoft Custom Optical 3000
Yep Shreddie like Bigmack I a getting a tad confused here as to what is not working.
I think you mean if you plug in your speaker system to the board audio socket (green) the audio doesn't play and yet it will if you plug it into where the monitor plugs in it does . What I can't quite work out is what sort of cabling are you using for the monitor?
If you have DVI then you would need separate audio cable / link if you are using HDMI then you don't need that audio link for the monitor.
So can you clarify what is plugged into where and with what please.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
the internal speakers; any other speakers or headphones I remotely plug in from the outside work. the audio that is integrated in my monitor/computer doesn't work
2048MB RAM
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
Logitech M305
Hey Shreddie I am sorry mate and I am not trying to be obstructive but I am still not sure what you are plugging into what.
I see in your specs you have a ? dedicated in a PCI slot sound card? if so like my Asus Xonar cards it will shut off the motherboard's audio so that you could not use it's green (audio) socket.
If you are using some sort of software that gives you the ability to change and / or mix frequencies then you would still be using the motherboard audio socket.
Now where the monitor audio is coming from I can only guess that you are using an HDMI cable.
So we need to know a) is there a drop in ( motherboard slot) audio card b) where and how is the monitor plugged into the computer.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
not exactly sure how to find the answer to either of those questions (my dad built me this computer some 7 years ago), but I do have a Realtek HD Audio Manager. I think the audio wire from my monitor is in the back analog panel (here's a picture)
http://gyazo.com/a245623b2a5a77d9f30a93522d918d34
2048MB RAM
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
Logitech M305
Right Lucas sorry bout that missed seeing your name - mate then you have the software and not a sound card.
So I guess you are using the blue VGA plug for the monitor - see pic sorry about the spelling.
Do you know how to use the Device Manager?
Plus just as matter of pure coincidence I downloaded the RealTek HD centre last night and I had a torrent of malware along with it.
So it begs the question have you scanned recently for malware if not try these
Malwarebytes < free version
and
SUPERAntiSpyware | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware! < free again
Plus what security do you have on the machine mate and how long is it since you last cleaned the machine up? :)
Try the scans first then it will be a look in the Device Manager - let us know if you are confident with that one - not being funny but you would e surprised how many people are not fully aware of it.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
On my PC, I have speakers plugged into the PC in the green slot in the back. If I did not have those plugged in, I would get no sound. I am not sure where your sound is coming from. A simple solution would be get a pair of speakers and plug them in. You said that would work.
AMD Radeon HD6670
Asus VE228
1440 X 900
Three 120 mm Fans
and
I have Norton Security Suite, I scan at least once a week. The manager came with the drivers, and I'm pretty sure the drivers are official drivers.
also, the wires at the back of my monitor are green (I think that one's the audio cord), white, (I think that is what connects the monitor to the computer to display the pictures) and a black one (for the power). and yes, I am fairly sure that I know how to use the device manager
2048MB RAM
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
Logitech M305
2048MB RAM
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
Logitech M305
I would suggest going to the Gigabyte site and use the driver they have posted.
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Hum Mack I saw that Lucas had the speakers in the first post what is throwing me is what is failing.
Ok Lucas that was shot of your monitor right? What we need is a pic of the rear of your computer to see what is hooked up there as you say you have a green cable hooked up there but as stated mate the pic is the monitor, I can see no green connection.
Now as I said if you use DVI to the monitor like I said you will not get sound from the monitor speakers the DVI is purely graphical data.
Have a look at the pic I sent it is that panel we need to see with hwatever you have connected.
Let get that sorted first.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
currently dling newest drivers; here is the back of my comp
imgur: the simple image sharer
2048MB RAM
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
Logitech M305
Ok now we might be getting somewhere that is the speaker socket you are plugged into there my friend.
Yes you have the onboard audio and yes it is software driven.
So there is no sound from your speaker set up hooked up like that?
If not can you go to and just check in Device manager the Sound - see my pic.
Just try what I have put in the pic if everything is ok then I know this sounds (no pun) stupid but can you check to see if the speakers or system works on something else it could be something as simple as that.
I am not being funny but are they just speakers and not some powered system?
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
yes, here is a pic, but it is there, and windows says it is working correctly. when I finish installing the drivers from the official gigabyte site I will update you c:
2048MB RAM
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
Logitech M305
Ok Lucas now if the Gigabyte drivers don't solve it then this is where you will find the Realtek stuff Realtek
Just one word of caution here - this is what I downloaded last night and it might have been coincidental but I did get a lot of malware afterwards.
So just as a precaution my friend I would strongly recommend you download and install those two anti malware apps I mentioned.
They are always good for everything and just about everyone I know on this site uses and swears by them. Plus they will pick up quite a bit at first of stuff that your Norton may have missed.
Let us know how you go:)
John
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
John
drivers didn't work, but I'm gonna install my actual monitor drivers now. I'll update you after
2048MB RAM
Viewsonic VX1962WM
1680x1050 59Hz
500MB HDD
Logitech M305
No probs Lucas I wasn't holding my breath on the Giga site ones anyway. I have a Giga in this machine and I know the support is pretty ordinary.
Oh by the way don't forget those malware apps my friend even if it comes up nothing you have lost nothing and there again there may be something - sounds a bit gobbledegook but.....
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
