Windows 7: Realtek onboard sound. No sound
02 Dec 2012   #11
kashifpclogix
win 7 64 bit AMD
You can go to the vendor site life dell support or Hp support or just call me at 1800-331-6968 i will fix your problem for u
02 Dec 2012   #12
VitaminK
What Vendor site? if you read the thread I've tried all the drivers and I don't have a Dell or HP computer, I custom built mine.. I'm not going to call you either..
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
Realtek onboard sound and PunkBuster
Hi people ! Im currently having some compatibility issues with my Realtek sound card and any game that uses PunkBuster, being Lockups and freezes with looping sound. After diggin up a bit I found that this is a common problem with Realtek onboard sound cards and PB. Im currently trying to...
Gaming
Realtek onboard sound card: Static/Crackling noises
Hey, I recent put together this new rig. I'm using the onboard sound card for my Gigabyte GA-X58A-UD3R Rev 2.0 mobo. The sound chipset is Realtek ALC889. I've updated the latest drivers, but there is crackling/static noise when I play music. Currently I mainly use a 2.1 speaker system. But...
realtek ac97, onboard sound
hi guys, new here and is my first post, so i have a dell comp, with a realtek ac97 onboard sound card, now running windows 7, but have no sound coming from pc. have uninstalled sound drivers and reinstalled new ones, have done this 3 times now, but still no sound, finally i have sound going to...
Unable to install hot fix for my onboard realtek sound
i jumped from Win XP to Windows 7 but the problem now is i have no sound device installeed on the taskbar i tried to install my original driver but i have install a Kb888III.exe hot fix to install my driver properly but the installer says 'u require a minimum of windows XP sp2 to apply this fix' i...
Drivers
