Realtek onboard sound. No sound
VitaminK
12:53 PM
I don't know how to title this too well but yeah.
I have been using a USB headset for quite some time but I recently purchased some Audio Technica ADH-700's. I've plugged them in and woolah!..
Just kidding.. No sound at all :(
I have an Avermedia Live Gamer HD Capture Card and with getting it to work with a usb headset there was a few things that were required to be done.
as seen in this thread below:
How to: Avermedia Live Gamer HD and streaming BF3 (PC) | Oscar Mike
But now I've got a 3.5mm jack headphones and a 3.5mm Microphone in the mail I don't need the usb way. So I've gone back (Well I hope) to the settings before the thread but nothing happens.
I have tried reinstalling multipul Realtek HD Audio things..
Any help would be much appreciated!
Windows 7 Ultimate x64Intel(R) Core(TM) i5-2500K CPU @ 3.30GHzG.Skill Ripjaw F3-12800CL9-4GBXL 2X4GBAMD Radeon HD 6900 Series
ASUSTeK Computer INC. P8Z68-M PRO
Asus 24"
(1) Corsair Force 3 SSD (2) WDC WD10EARX-00PASB0 (3) WDC WD5000AAKS-00A7B2
Corsair HX750W
Coolermaster HAF 922
Have you reinstalled the ASUS supplied Realtek driver? In most cases the vendor (in this case motherboard vendor) driver works best. Non Vendor drivers can either not work or not work correctly.
Do you have the Audio Playback set correctly? The "Speakers" (in this case Realtek) should be set as the Default Audio Playback Device in the Sound Panel.
Also while you are in the Sound Panel, go to the Recording section and set the Stereo Mix as the default recording device.
Finally, make sure you have the front panel headphone/mic jack correctly connected to the motherboard front panel audio jack. The "HD Audio" connector from the front panel should be used (some also have an AC97 or only have an AC97 and that should only be used if there is no HD Audio).
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Hey, I've tried both the ones from my motherboard vendor and also, My front ports do work because I have used them in the past but I'm trying to run them out of the mobo itself.
I might try and re install the MOBO driver again and see if that helps with anything.
Asus 24"
Corsair HX750W
I've re installed the realtek driver from my motherboard and still no luck :/
Asus 24"
Corsair HX750W
I suspect the Avermedia card is causing the problems. Not sure how that works but that is probably the problem.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I don't see how though, Nor have other people who have the card had the problem
Asus 24"
Corsair HX750W
Are the speakers (internal sound card), as I've shown, set as default playback device?
Assuming you have the correct drivers installed, the main thing left is the Avermedia. Physically remove that, for testing, and see if you can get the front panel jacks to work. You have to break it down to the least components and start from there. Once you have it working with the basic components you can then add other things, such as the Avermedia.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Hey, Sorry for the late reply I've been away from my computer for a little bit.
I've taken out my Capture Card completely. My internal sound card is set as the default playback device.. Still no Audio. Through the front jack there is a weird sort of high pitch quiet sound going through them. But at the back nothing.
Any Idea what could be the problem?
Asus 24"
Corsair HX750W
Use MUA (Microsoft Universal audio driver ) now it depends the Operating system you have if you have upgraded your OS than it can be the problem you can send a screenshot of your system info it wil be a great help :)
win 7 64 bit AMD
win 7 64 bit AMD
I haven't upgraded my OS and I've been running on this install for like a year haha, I might need to reinstall windows :/
What do you mean screenshot of system info? also where is MUA at?
Asus 24"
Corsair HX750W
You can go to the vendor site life dell support or Hp support or just call me at 1800-331-6968 i will fix your problem for u
win 7 64 bit AMD
win 7 64 bit AMD
What Vendor site? if you read the thread I've tried all the drivers and I don't have a Dell or HP computer, I custom built mine.. I'm not going to call you either..
Asus 24"
Corsair HX750W
