Right Channel Audio To Left Speaker: How Please ?
  1. Posts : 542
    Windows 7 64bit
    Just bought a new set of desktop speakers.
    The volume and tone controls are on the right-side speaker.
    As I use my mouse, right handed, and the volume control more or less together for some work, this is a bit of a pain.
    I can, of course, just move the speakers, but my son objects; for some videos and games, I guess it is important to have right-right, and left-left.
    I have the Creative/Soundblaster audio setup.
    If I do interchange the speakers to the way I like, is there any option, anywhere,
    where I can have the left channel sound now going to the right speaker, and the right channel sound going to the left speaker ?
    Creative, and the MS Audio options doesn't seem to have a way.
    I don't want to re-wire any plugs.
    Any simple way of accomplishing this ?
    Thanks,
    Bob
  2. Posts : 1,686
    Thanks,
    Bob
    I know exactly what you mean. On my media PC the on board audio was backwards so I reversed the connections so it sounded correct. I then put in a Audigity 2 and that was wired correctly.
    The only suggestion I have is to check out an electronics store or Amazon for a couple of cables so you can reverse the wiring.
    https://www.google.com/shopping/prod...d=0CIABEPMCMAA
    and then one of these if your speaker system has a socket on it, if not search for a cable with a socket on it.
    https://www.google.com/shopping/prod...ed=0CHoQ8wIwBA
