Right Channel Audio To Left Speaker: How Please ?
Robert11
Power User
1:50 AM
Just bought a new set of desktop speakers.
The volume and tone controls are on the right-side speaker.
As I use my mouse, right handed, and the volume control more or less together for some work, this is a bit of a pain.
I can, of course, just move the speakers, but my son objects; for some videos and games, I guess it is important to have right-right, and left-left.
I have the Creative/Soundblaster audio setup.
If I do interchange the speakers to the way I like, is there any option, anywhere,
where I can have the left channel sound now going to the right speaker, and the right channel sound going to the left speaker ?
Creative, and the MS Audio options doesn't seem to have a way.
I don't want to re-wire any plugs.
Any simple way of accomplishing this ?
Thanks,
Bob
Windows 7 64bit
Windows 7 64bit
Thanks,
Bob
I know exactly what you mean. On my media PC the on board audio was backwards so I reversed the connections so it sounded correct. I then put in a Audigity 2 and that was wired correctly.
The only suggestion I have is to check out an electronics store or Amazon for a couple of cables so you can reverse the wiring.
https://www.google.com/shopping/pro...=X&ei=BpO_UNHuBbP3yAHp64G4CA&ved=0CIABEPMCMAA
and then one of these if your speaker system has a socket on it, if not search for a cable with a socket on it.
https://www.google.com/shopping/pro...=a5O_ULSWEenxygG074GACA&sqi=2&ved=0CHoQ8wIwBA
Windows 7 x64 Ultimate and numerous virtual m...AMD FX-8350 Vishera 32nm Technology @ 4.2 GHz...G Skill 32.0GB Dual-Channel DDR3 @ 1204MHz (1...EVGA GeForce GTX 960 4GB Super SC ACX 2.0+ wi...
Bluethunder II
LG L227WTG x 3
1680 x 1050 16:10
Rocketfish Full Tower
Logitech K740
500 mbs down and 30mbs up
