Use sound over HDMI
  1. Posts : 180
    Windows 7 Ultimate x64/Windows 8.1 Pro x64
    Use sound over HDMI
    My motherboard has two seperate sound capabilities. The normal sound outputs [Jacks in the back, headphone jack in the front] and sound over the HDMI.
    I use our 37 inch flatscreen as my second screen, and if I put a Blue Ray in, the software asks me if I want to use the regular sound, or the HDMI [and the sound comes out my TV]
    I do not know how to put anything else to the TV speakers, and I was hoping somebody can tell me what to do to fix that.
  2. Posts : 21,004
    Thing is Joes is where do you want the sound to come from.
    Personally my TV speakers are pretty ordinary and I have my stereo hooked up to the TV to pick just enough signal from it to give me a decent "surround sound" system.
  3. Posts : 180
    Right now, it is as a learning tool. Later it will be an attempt to put my VirtualBox Windows XP on the seperate sound source.
    It would also help when we want to stream movies.
    I want to be able to move the sound from one to the other output device at will, preferably being able to choose what app gets which sound...
    [For the record, either way, the only option [setup] is simple 2 speaker sound.
  4. Posts : 21,004
    Hum I am not so sure if you are going to be able to run two sound sources off of one board Joe.
    I am not real conversant with virtual machines either as I have never tried running one - sorry mate.
