Windows 7: No sound after installing sound drivers?
15 Dec 2012   #1
Windows 7 Ultimate x86
New Jersey
I installed a driver for my sound card, only to find out that sound just wouldn't play on my laptop. (It says that the sound is playing, it's just that it isn't coming through the speakers.) I know that the drivers are updated, so if you're going to ask if my driver is updated, the answer to that is yes.
At first, I had thought that it was only a problem with the driver, or the hard drive, but that's not it... I don't know what the problem is. I've tried looking for solutions online, but absolutely nothing worked.
Can someone help me? I don't want to be stuck with the generic "High Definition Audio Device" which will just mute the speakers at the most random times.
Oh, and the sound driver that I have is "SoundMAX Integrated HD Audio", just in case anyone was going to ask.
15 Dec 2012   #2
Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit
Citrus Co, FL
Are you using the correct HP provided sound driver? Generally, the PC Vendor's driver works or works best. Non-Vendor drivers in many cases do not work properly.
If the new driver install was recently, rollback the driver - function available in the Device Manager or use the System Restore and restore the PC back to an available restore date prior to the driver install.
 No sound after installing sound drivers? problems?
Similar help and support threads for: No sound after installing sound drivers?
"HD Audio" drivers keep installing - disabling my recording sound card Sound & Audio
Sound card drivers show as working but still no sound Sound & Audio
Cracking sound after installing realtek HD audio drivers.... plz help Sound & Audio
Nvidia sound drivers, realtek drivers, or both? Drivers
FPS drop because of sound card / sound card drivers? Gaming
