Windows 7: Help with audio, audio goes out when computer sleeps.
26 Dec 2012
HS5964
Windows 7 64 bit, home premium
As the title says, sometimes when my computer goes to sleep, my audio drivers crash. This is only sometimes, most of the time it's good. I tried updating the driver, but the updater crashed during the update, and now I get this screen every time I power on my PC.
27 Dec 2012
fireberd
Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit
Citrus Co, FL
Go to the Device Manager, RIGHT click on the entry for the RealTek to highlight it and then LEFT click "Uninstall" Also check the box to uninstall the drivers. Then restart the PC and when Windows starts it will reinstall the RealTek. Not sure what driver Windows will install, but try installing the correct RealTek driver again. Use the RealTek driver supplied by ASUS, as the vendor supplied driver is usually the best.
This may also take care of the random sound problem.
 Help with audio, audio goes out when computer sleeps. problems?
Similar help and support threads for: Help with audio, audio goes out when computer sleeps.
Asus onboard audio no longer working since enabling front panel audio. Sound & Audio
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou BSOD Help and Support
Solved Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox Sound & Audio
I need an audio player capable of playing multiple audio files simul Sound & Audio
