Solved Gigabyte HDMI output to Yamaha receiver - no sound output
Lee K
9:56 PM
GA-890GPA-UD3H (rev. 3.1)
GIGABYTE - Motherboard - Socket AM3+ - GA-890GPA-UD3H (rev. 3.1)
(Note 3) Simultaneous output for DVI-D and HDMI is not supported.
What I'm trying to do is output just my sound to the receiver via HDMI cable, but still use the DVI to my monitor for video. From the note above taken from the MB specs, sounds like this is not possible.
This is new business to me and wondering how others do this, seems little information I can find. I am ordering a HDMI to DVI cable so I can disconnect the DVI cable from the computer and instead run both video and sound through HDMI to the receiver, then the video to the monitor. Hoping this works.
If all fails then I am relegated to separate digital through S/PDIF optical link, to my receiver. According to the experts this is less than ideal since now, the multi-channel dolby and DTS signals can only be received via HDMI.
Wondering if I get a Blu-ray player for my computer how this is going to all work out. Hoping that HDMI to DVI cable does the trick.
Anyone with experience with this kind of set-up and the aforementioned hardware greatly appreciated.
And Happy NEW YEAR!
Windows 7 Ultimate 64 bitAMD Athlon II X4 640 Quad Core Processor AM3 ...Mushkin Enhanced Silverline Stiletto 8GB 2X4G...Radeon HD 6850 775MHZ 1GB 4.0GHZ GDDR5
Own built
AMD Athlon II X4 640 Quad Core Processor AM3 3.0GHZ 2MB L2 C
Mushkin Enhanced Silverline Stiletto 8GB 2X4GB PC3-1066
Realtek (onboard) dig. out to Yamaha RX-V573
Samsung 32" Smart TV HD UN32EH5300F
1920 x 1080 i
2 x SSD (OS) & 1 x HDD (data)
Antec 850W
Lion Li
i-rocks (usb)
Logitec G700S (run usb)
325 KB/sec
Bitdefender Total Security
IE 11
Windows Base Score: 5.3
This is a do it all PC / Media Center with sound output to an external receiver. Plays all games, TV, Video, all controlled via a tablet. A second computer acts as a backup for data, and in case the main goes down.
As you have a separate video card, its capabilities should determine how the video works, not the motherboard. The video is routed to the video card.
If you had some type of integrated Video on the motherboard then the motherboard's specs would apply. For example, I have an Intel i7 3770 CPU and this model has built in Intel HD4000 video which is routed to motherboard video connectors and thus the motherboard would determine how the video is distributed. However, I'm using a separate video card and thus that determines how video is distributed.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Updated my system specs to my newer ATI Video. Forgot that, yes, I am running a Video card, so how do I pull digital Audio to my receiver? Seems if you try to use HDMI, it is always linked with video. I tried setting system sound output (playback) to HDMI audio, but no sound is produced from that mb HDMI output. Tried plugging HDMI cable into the ATI video card and as soon as I do that it blanks out the Video on the monitor. Seems like I will have to wait for that cable.
My last try while I'm waiting for that HDMI to DVI adapter cord is a S/PDIF optical cable, the only thing that sounds like it might work.
Eventually I will be updating my monitor to a one with HDMI input, and this should solve some of the problems.
One of the main problems I have experienced is way too much noise through the analog links, hoping this does away with most if not all those problems
Own built
1920 x 1080 i
Antec 850W
Lion Li
i-rocks (usb)
325 KB/sec
IE 11
Well the S/PDIF did it. The cable is barely long enough but the 3' reached. Plugged it in, got a lot of cracks and pops :( but finally sound to my AKG headphones! Took a quick survey and found the optic needed to be pushed in about a mm more to make a definite locking "click" on both ends and wha-la pure sound, that I can play with to the nth degree, either on the PC or the receiver or both.
Blu-ray player to add, new monitor, but first to build my bookcase speaker, towers and surrounds. :)
Own built
1920 x 1080 i
Antec 850W
Lion Li
i-rocks (usb)
325 KB/sec
IE 11
I've seen audio optic cables go bad if they are "misused" - bent too much, over stretched, whatever...
I think Optic cables are "too" delicate in that sense...
You might consider buying a longer 6' cable, and use the 3' for a backup...great to have on hand for trouble shooting.
As it's working now, wait till you find a good sale price to buy.
home built
AMD Athlon II x4 620
Gigabyte GA-MA785G-UD3H
6GB GSkill DDR2 800
AMD 4670 GPU + AMD 4200 IGP
on board Realtek ALC889A
OCZ Vertex 3 120GB,
Samsung F3 1TB (3),
Corsair 500 W
Rosewill mid tower
CM 90mm rifle
Avast, MBAM3, EMET, WinPatrol
Pale Moon, Firefox, IE
2 multi-boot PC's
Trendnet USB KVM.
Yeah expensive beasts, Wallymart was my only choice on New Years day, going to order a second longer one, good idea. Still learning this end of things but so far seems like things are working out after some learning curve.
Own built
1920 x 1080 i
Antec 850W
Lion Li
i-rocks (usb)
325 KB/sec
IE 11
