How to Normalize a channle sound from a stereo sound file.
  1. Posts : 138
    Windows 7 SP1 Ultimate x64
    Hi to all seven forum,
    I have a movie audio and its left channel sound is lower then the right side. so I wanted to Increase left channel sound for equal to right side channel. I used Audacity but its "Normalizer" option didn't really works.
    see the image, there is clearly shown one channel sound is lower then other.
    The waveform for the bottom channel (whichever that is) shows it is distorting and too loud on the sound peaks. Lower that channel to match the other.
    (I have a recording studio and work with audio daily).
  3. Posts : 138
    but where are answer.?
    how I lower the louder channel.?
  4. Posts : 8,135
    I don't know how to do it in the program you have (Audacity?) but there should be a way.
    I use Goldwave audio editor and have control over individual channels.
  5. Posts : 138
    hmmm, Goldwave, I'll check that. thanks.
