How to disable SRS Sound Premium?
NBAPwns13
7:57 PM
It's conflicting with my 7.1 sound card...
Is there a way to disable it and enable it?
Also if i were to remove the IDT High Definition Audio Codec - Speaker and Headphones and Communications Headphones does that mean i won't have sound on my computer when i want to use the computer speakers and not my headphones?
Please reply cause i never get replies on this thread when asking for help :)
- Happy New Years 2013!
Windows 7 Home Premium 64-Bit
try this, right click the speaker icon in the systems tray (bottom right of taskbar)
select playback devices, srs should show ,maybe as default
click your other playback device and set it as default, see if that helps.
i wouldnt remove the high def codecs .
Hewlett packard/p6512uk
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
Okay so i followed what you said and his is what i got :
hmm, no sign of the srs, right click in the sound playback window and check show hidden devices,see if it shows.
what way is the srs conflicting?
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
Well what got me thinking is that im using a 7.1 Surround Sound Card for my Headset right, so i really want to see if its actually working on the sound.
I have 2 sound enhancements that boost my sound which is the SRS and the Sound Card application. When i change around the volume settings on SRS the volume changes.
I checked and its not on there its on my start menu
it will be in control panel.
seems to me that your srs device is acting as the default device despite the usb being set to default.
im thinking that you dont need to have the usb card set as default. im guessing that when you use it with your headphones then it would work as it should ,leaving the srs device to function as it should when the phones and 7.1 are not in use.
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
The entry for the only sound device that shows as enabled on the list looks a little generic, I would check on the manufacturer's site and see if there is a later driver available, a lot of windows update supplied drivers are cut down versions that do not provide control of all options, they are there just to get you up and running - the prime example of this is the Realtec drivers, these are on WU but do not have and real controls available whereas the full drivers available from the manufacturer have all the bells and whistles
    Ryzen 9 5950X, 3.8 - 5.2 MHz
    Asus Prime X570-Pro
    64GB [2 x 32GB] DDR4 3200MHz
    2 x 3840 x 2160 @60Hz
    Workstation Case [Matt Black]
    920 MB Down 50 MB Up
    Also run ...
    Nexus 7 Android tablet x2
    Samsung 10.2" tablet
    Wacom Expresskeys Remote
    Loopdeck+ Graphics Controller
    Shuttle Pro v2 Control
    Dell XPS 17 10750H
    Windows 11 Pro x64 Latest RP
    Intel I7 10750H 5.0GHz
    Dell XPS
    32GB [2x16GB] DDR4 2933 MHz
    nVidia GTX1650Ti 4 GB GDDR6
    Stock [Realtek] 4 Speaker
    3840 x 2400
    Stock - Active Fan Control
    Backlit + Various Logitech
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    Sony Z3 Android Smartphone
    Shuttle Pro v2 Control Pad
    10TB NAS
What drivers am i suppose to look for ? like what kind specifically
Check for a website for the manufacturer of the actual USB audio device, hopefully they will supply device specific drivers for the actual kit they make. There should be a set of device specific drivers supplied with the kit when purchased or maybe a link address in the documentation
This is not always easy to find as a lot of smaller manufacturers will buy in the actual audio hardware from another company so it is then a case of ascertaining the actual audio chips used It would seem that in this case they may be IDT chips though there does not appear to be any drivers available on their site from a cursory glance
    Asus Prime X570-Pro
    Also run ...
    Dell XPS 17 10750H
    Dell XPS
    3840 x 2400
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    10TB NAS
I do have the latest driver and when i search up the download for my usb it gives me 1 download on the main site where this headphones are which is steelseries.com where they give me the driver download.
