No audio through monitor speakers via HDMI
  1. Posts : 8
    Windows 7 Ultimate N x64
    I purchased a new monitor and it looks great but I can't get the built-in speakers to function. The monitor has inputs for VGA, DVI, and HDMI and I currently have it connected to my video card via HDMI. The front panel audio jack is functioning and I am able to hear audio if I plug headphones in but unfortunately I don't have any external speakers. From the sound menu I have three playback options: Speakers, Realtek Digital Output, and my monitor. I would like to sort this problem out quickly so I can play some games without using earbuds.
    Attached Thumbnails Attached Thumbnails No audio through monitor speakers via HDMI-vs248.png
  2. Posts : 9,606
    Welcome splooge :)
    Does the Monitor have any standard speaker jacks (for input) ?
  3. Posts : 8
    I believe so, there is an input on the back with headphone symbol above it.
  4. Posts : 9,606
    You probably need to connect a Male / Male speaker cable from the computer output to the monitor input
    Saw this this on eBay for $2.60, but you could check, Amazon, NewEgg, & TigerDirect :)
    Attached Thumbnails Attached Thumbnails No audio through monitor speakers via HDMI-speaker_cable_m-m.jpg
  5. Posts : 8
    I have these, still no sound.
  6. Posts : 9,606
    Is there any volume control button under the edge or on the side of the monitor ?
  7. Posts : 8
    I can access volume controls through the menu only, its currently set at 80.
  8. Posts : 9,606
    What is the make & model of the monitor so we can research it ?
  9. Posts : 8
    Asus VS248H-P 24". I filled out all my system specs earlier but maybe its not showing up
  10. Posts : 9,606
    My search says that is an earphone output jack on the monitor, NOT an input Sorry.
    Did it come waith any manual ?
