No sound through 5.1s... only headphones
Hi guys,
I just built my new computer (Gigabyte mobo p55-ud3r + 4gb Ram + i5), but I can't get the sound working with my old 5.1 speakers, which worked fine on vista before. Thing is, when I connect my headphones, the sound works.
Should there be a difference? I can't even check to see if the surround sound speakers work anymore to eliminate a possible problem.
Thanks for your help!
cody
