Speaker/Headphone problems.
  1. Posts : 1
    Windows 7 32bit
    Good afternoon, My laptop (Toshiba Satellite L650) Stopped playing sound out of the Speakers. I recently fixed this rolling drivers back, and disable/reenabling them.
    This resulted in me having to disable the speakers, and restart every program that I wanted sound to play from so I was able to listen to the sound from my headphones.
    Now, after almost a week, my speakers are not producing any sound at all. As they are internals, I cannot test them on something else.
    I don't know whether there is an issue with my sound card, that is causing it, but my headphones play perfectly fine.
    So, basically, I would like to know, how to fix my Internal speakers, and how to make the swap between Speakers and Headphones, automatic, so I don't have to close everything, and then disable the device I do not want to use.
    Thank you, and have a great day.
  2. Posts : 21,004
    Hello and welcome Zeroix mate have you tried just plugging in headphones? and do they work if not check the small speaker icon at bottom right click on it and it will show the volume level and check Sound in Control Panel - see pics
    Attached Thumbnails Attached Thumbnails Speaker/Headphone problems.-speak.png   Speaker/Headphone problems.-speak2.png
