Windows 7: Speaker/Headphone problems.
16 Jan 2013   #1
Zeroix7
Windows 7 32bit
Good afternoon, My laptop (Toshiba Satellite L650) Stopped playing sound out of the Speakers. I recently fixed this rolling drivers back, and disable/reenabling them.
This resulted in me having to disable the speakers, and restart every program that I wanted sound to play from so I was able to listen to the sound from my headphones.
Now, after almost a week, my speakers are not producing any sound at all. As they are internals, I cannot test them on something else.
I don't know whether there is an issue with my sound card, that is causing it, but my headphones play perfectly fine.
So, basically, I would like to know, how to fix my Internal speakers, and how to make the swap between Speakers and Headphones, automatic, so I don't have to close everything, and then disable the device I do not want to use.
Thank you, and have a great day.
16 Jan 2013   #2
ICIT2LOL
Hello and welcome Zeroix mate have you tried just plugging in headphones? and do they work if not check the small speaker icon at bottom right click on it and it will show the volume level and check Sound in Control Panel - see pics
Speaker/Headphone problems.-speak.png Speaker/Headphone problems.-speak2.png
I can only hear out of my right headphone and speaker
I have start to get this problem today i have looked around to find fix but nothing. i have 2 sets of ports and both of them only play throw the right hand side. also i do not know how to check if it is on mono that might be the problem but i dont think so. i have tried my headphones on my brothers...
No speaker or headphone plugged in
I have seen this thread and i did everything,but when i restart my computer the HDMI comes back instead of my speakers PLZ help i have found no way to figure it out and i have just installed windows 7...
Sound coming from both headphone & speaker but headphone is not detect
I have Lenovo 3000 Y410 laptop having Windows 7 Home Premium installed on it. Realtek HD Audio latest driver is installed. But from the last 3 days, when I connect headphone through laptop, following things happen : - 1) Headphone connected popup doesn't show up. 2) Mic of Headphone connected pop...
speaker/headphone not plugged in
hello friends i have a problem here firstly i'll tell you -i have tested my speaker on another komputer and working properly -i have checked on device manager, sound, video and game controllers have status "this device is working properly" -i have instaled the latest realtek driver for my...
No headphone or speaker device.
I recently got the Sound Blaster Tactic 3D Alpha headset for Christmas and tried them out. I plugged in the USB thing that came with it, which allowed you to plug the headphones and mic into a USB port, and it installed the device fine. Right now I have to send them back because of a problem with...
Right headphone speaker out
My right headphone speaker wont work. I have had problems with there being no audio before but all i had to do was reboot my computer. But now im only hearing it out my left headphone. Is there a fix for it?
