Windows 7: HDMI Sound Works but Audio Jack Doesn't
17 Jan 2013   #1
Windows 7 Ultimate 64-bit
I built a barebone kit and installed Windows 7 Ultimate 64bit, I installed all the drivers correctly but for some reason Windows keeps detecting the front audio jack as if someone is repeatedly pushing in and out headphones(no pun intended). Audio doesn't work at all through front and back audio jacks, only HDMI. I only get static from the audio jacks.
18 Jan 2013   #2
Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit
Citrus Co, FL
Possibly defective front panel headphone/mic connector/cable or problem with case front panel. Most cases have both an HD audio and an AC97 connector for the front panel, that plugs into the motherboard. Normally, the HD Audio should be used. If you are using the HD Audio connection, try the AC97. If you are using the AC97, use the HD Audio instead.
If neither of the connectors change anything, and the audio works OK with the rear connections (with no front panel connection to the motherboard), the problem would appear to be in the case front panel assembly.
19 Jan 2013   #3
There's only one kind of audio in my case.
 HDMI Sound Works but Audio Jack Doesn't problems?
Similar help and support threads for: HDMI Sound Works but Audio Jack Doesn't
HDMI sound output works just fine, audio jacks not at all! New PC Sound & Audio
No audio from rear jack & no hdmi audio Graphic Cards
No dvd audio via hdmi, but mp3 and itunes works Sound & Audio
Sound over jack works, not over Speakers Sound & Audio
Surround sound works via HDMI, but not WMV's, no audio Sound & Audio
