Device working but sound doesn't come out Digital Audio S/PDIF
I have a problem with audio, after upgrading to windows 7 home 32 bit, I installed all the drivers that are neccessary for windows 7. My audio device is High Definition audio device but the only device I can see is Digital audio S/PDIF. Other devices that may be disabled don't appear. I installed all of the Realtek drivers for on board audio device. and I tried installing several others aswell but with no luck. I tried all of the solutions that I was able to find online and nothing works. My microphone works cause I tested it with a friend on skype which gives me the reason to believe that the actual device works.
When I install Realtek driver, it won't show up in my device manager, or sound (only Digital audio), when I run troubleshoot compatibility on any Realtek drivers it detects that the driver is not compatible with my system. I uninstalled my driver that automatically installs on every boot and then I disabled the automatic driver install, and I disabled automatic updates to prevent auto install of the driver that clearly doesn't work. but on the next boot the driver automatically installs again.
The audio doesn't work when I plug my speakers in any port and I dont have front jack on this PC.
I have Pentium D dual core 3.0ghz 4gb Ram and my hardware ID of HD audio device is HDAUDIO\FUNC_01&VEN_11D4&DEV_1986&SUBSYS_1043818F&REV_1005
HDAUDIO\FUNC_01&VEN_11D4&DEV_1986&SUBSYS_1043818F.
I totally ran out of ideas, it's 4 days that I'm trying to find a solution to the problem. Any help is appreciated.
