Windows 7: Is there a way to enable both optical audio and the stereo jacks?
25 Jan 2013   #1
ILikePie
Windows 7 HP
I just picked up a set of gaming headphones that use optical audio for its source, but I also have a set of 5.1 surround speakers. I'd like to be able to just use the headphones when I want to without having to go into sound manager and make the optical plug the default audio source every time I want to use them. Is there a way to enable both audio sources at the same time or do I have to switch them every time? Thanks for any help in advance!!!
25 Jan 2013   #2
fireberd
Short answer is NO. Windows will only allow one "default" audio playback device. Thus you will have to manually change as your are doing.
05 Sep 2013   #3
mayhem2k
Win7 Ult 64bit
This worked in XP so it is a limitation of MicroCrap's new OS.
06 Sep 2013   #4
fireberd
It can be done in XP but you need the KMPlayer, a 3rd party application.
19 Sep 2013   #5
mayhem2k
Win7 Ult 64bit
I don't recall having a 3rd application when I used it in XP. Then again, almost everything is a 3rd party application to XP
22 Sep 2013   #6
jimbo45
Hi there
This might work -- do your 5.1 speakers also have a "Headphone" output socket -- I'm using a BOSE computer sound system and when I want headphones I just plug the cans into the BOSE headphone socket while leaving the optical connection from computer to sound system in all the time.
If you need an extra long cable there are plenty of double ended jack cables you can buy cheaply (female at one end for your cans and male at the other end for the "phones" connection).
Cheers
jimbo
22 Sep 2013   #7
Lady Fitzgerald
Win 7 Ultimate 64 bit
Quote   Quote: Originally Posted by jimbo45 View Post
Hi there
Cheers
jimbo
One of the things I like about my new Corsair SP2500 2.1 speaker system is it has a control pod on the desk that has a headphone jack in it.
The technical term for the cable you are referring to is extension cable. A good place to get them is Monoprice.com. I recently bought some from there for an experiment I did.
22 Sep 2013   #8
N00berG00ber
Windows 10 Pro
if you are using realtek, you can enable front panel and rear panel playback simultaneously. you could then plug your head phones in the rear and your speakers in the front panel headphones. its in the settings in realtek.
or you can find a splitter of some sorts. maybe aux to aux and digital
23 Sep 2013   #9
jimbo45
Hi there
Another suggestion
You can get a separate DAC (Digital to Analog converter).
These usually have a Digital "Pass thru" -- connect from the digital O/P on the computer to your 5.1 system and plug your Phones into the Analog jack. - Don't go overboard though as DAC's go from cheap to HIDEOUSLY EXPENSIVE costing several THOUSAND US dollars !!!
Cheers
jimbo
No sound from rear audio jacks after installing W7
Hi there, first of all nice job on this forum, as it seems this one is one of the most active for windows 7 help. I hope you guys can help me out. My problems began after I clean re-installed W7. My rear audio jacks are not being recognised in device manager, and plugging in my headphones won't...
Optical output sending only stereo
I can't get my pc to output 5.1 audio through my spdif. My ht shows what is coming in, sound wise. I get 5.1 from my dvr, but not my pc. I'm running on board sound and video, my video card died. Please help. I have an Asus m4a78-em mobo. realtek hd.
Cannot get audio on any jacks.
I have an HP P6620f desktop. I have a pair of speakers that I have tested on other computers and had working on this system until recently it stopped. When I plug the speakers into the back port and turn the volume up max on the speakers itself and the in OS sound options I can faintly hear the...
audio jacks
So I just got a new dell studio xps 9000 and it has no audio jacks at all. I have a logitech thx system but there is no where I can hook it up. I was wondering do the new computers have their sound output from the usb drive? So would this mean I need to find a converter from the three jacks to one...
Need help with AUDIO IN jacks..
I have an M9350f elite series from HP. There are audio IN jacks in the back of the tower and two in the front. I'm trying to hook my PS3 component cables up to my tower and play the sound through my speakers, but whatever I try does not work.. the PS3 is outputting sound via component cables.. ...
audio jacks
IN W7 how do I make it so that both the rear and front audio jacks work? Currently, my front jacks are registered devices in my sounds but when I put a headphone jack in nothing happens
