Windows 7: Creative Sound card problems
28 Jan 2013   #11
sparks72
You can try this if Windows is auto installing drivers.
  1. Go to Start–>Search type in gpedit.msc
  2. Click the file to open the Local Group Policy Editor and show Windows who is in control!!
  3. You want to go here: Computer Configuration->Administrative Templates->System->Device Installation. Click on the sub folder Device Installation on the left and on the right side you will see the possible restrictions.
  4. Right Click on Prevent Installation of Devices not described by other policy settings and edit this option, set it on ENABLED.
  5. Reboot Windows and enjoy its inability to pollute your system with its standard driver, open gpedit.msc again and revert the change so you will be able to install your driver.
28 Jan 2013   #12
ROCKNROLLPIMP
when I type in gpedit.msc
I get the proverbial no item match your search
28 Jan 2013   #13
Dwarf
Windows 8.1 Pro RTM x64
The Group Policy Editor, gpedit.msc, is NOT available in W7 Home Premium.
28 Jan 2013   #14
ROCKNROLLPIMP
right on
thanks Dwarf!
28 Jan 2013   #15
sparks72
That's kicked that idea in the head then........
28 Jan 2013   #16
ROCKNROLLPIMP
whoops
29 Jan 2013   #17
sparks72
I really don't know what to suggest apart form removing all Creative drivers and reinstalling from scratch.
29 Jan 2013   #18
ROCKNROLLPIMP
it has completely stopped working now
and will not even recognize the card
i have even did a fresh re-install of my whole system and re-seated the sound card
i am at a loss.....
29 Jan 2013   #19
ROCKNROLLPIMP
I guess I need to figure out how to tell if the card has gone bad....gonna try n re-seat it...AGAIN
30 Jan 2013   #20
sparks72
Try this link............
http://www.askdavetaylor.com/how_to_diagnose_fix_sound_problems_windows_7_pc.html
If you don't have any luck with that, try this instead......
http://www.passmark.com/products/soundcheck.htm
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Creative sound card not detected
Hi, I have just acquired a creative Audigy 2 Platinum Pro (Model SB0290) from a friend, however Windows can't detect it so I can't install the driver. In device manager a device called Multimedia Audio Controller shows up under Other Devices. Thanks in advance!
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Sound card
I've got a Creative Sound Blaster X-Fi Xtreme Audio. I have 2/2.1 speakers. What jack in the back of the card should I be in? When I run creative diagnostics I hear the left and right speaker but not my center speaker. With the 2/2.1 speakers do you stay in the green jack?
Upgraded to W7. No sound. Creative Xfi card. Help!
I upgraded from Windows XP to Windows 7 Home Premium 32 bit. My sound card is a Creative X-Fi Audio Processor (WMD). I am not sure if that is the actual model name. That is the name that the device manager gives me. RE-installing drivers from Creative doesn't help. Tried the Daniel_K drivers and...
Problems with my Creative Sound Card.
Hi all, I've been having problems with my sound card drivers ever since I upgraded to Windows 7 64 from Windows Vista 32. I must admit I messed up by not writing down what specific sound card is in this laptop (Dell Inspiron 1520) and I have not been able to find any drivers from Dell.com. I...
Drivers
