Windows 7: Creative Sound card problems
30 Jan 2013   #21
ROCKNROLLPIMP
Will do thanks Sparks
I am using on board sound at the moment (dull)
I am out of work or I would just go buy another one....
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Creative sound card not detected
Hi, I have just acquired a creative Audigy 2 Platinum Pro (Model SB0290) from a friend, however Windows can't detect it so I can't install the driver. In device manager a device called Multimedia Audio Controller shows up under Other Devices. Thanks in advance!
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Sound card
I've got a Creative Sound Blaster X-Fi Xtreme Audio. I have 2/2.1 speakers. What jack in the back of the card should I be in? When I run creative diagnostics I hear the left and right speaker but not my center speaker. With the 2/2.1 speakers do you stay in the green jack?
Upgraded to W7. No sound. Creative Xfi card. Help!
I upgraded from Windows XP to Windows 7 Home Premium 32 bit. My sound card is a Creative X-Fi Audio Processor (WMD). I am not sure if that is the actual model name. That is the name that the device manager gives me. RE-installing drivers from Creative doesn't help. Tried the Daniel_K drivers and...
Problems with my Creative Sound Card.
Hi all, I've been having problems with my sound card drivers ever since I upgraded to Windows 7 64 from Windows Vista 32. I must admit I messed up by not writing down what specific sound card is in this laptop (Dell Inspiron 1520) and I have not been able to find any drivers from Dell.com. I...
Drivers
