Creative Sound card problems
ROCKNROLLPIMP
Rock-noob
10:58 AM
Macon,Ga.
ok here goes
I have read about 62 pages of threads looking for answers and tried the pinned post here about Creative sound cards
THIS is going to be a long one ;)
I had this computer built for me and have basically had problems updating the drivers,program from day 1
Only change I made to this computer was I installed a creative Audigy Value 2 sound card to it.
I have the Logitech Z-5500 THX-Certified 5.1 Digital Surround Sound Speaker System
My problem is when I went to the website (Creative support) I found the correct updated driver but when I installed it some key features were missing...I tried and tried to research the problem but came up with no definitive answers,got the program to work (but IMHO never sounded nor worked as good as it did with my last system a XP OS).So I just settled.:(
I found windows 7 forums attempting to get help with a BSOD problem and the sound forum threads
I read the pinned thread by stormy13 on creative cards and went and installed the Audigy Support Pack for my card/system.Would not install. Then I tried the Audigy Support Pack 4.5 and lo n behold it worked! It returned some of the key features I lost last time (all except for Creative EAX console,see attached screenshot)
Also the center channel speaker will now only work on the PLII Music n Movie setting :huh:
Any advice,insight and direction greatly appreciated :thumbsup:
Microsoft Windows 7 Home Premium 64-bit 7601 ...AMD Phenom(tm) II X6 1055T Processor4.00 GBATI Radeon HD 4250
Custom built
MICRO-STAR INTERNATIONAL CO.,LTD 880GM-E43 (MS-7596)
4.00 GB
ATI Radeon HD 4250
Creative Audigy Audio Processor
22" Envision
1280 x 768 x 32 bits (4294967296 colors) @ 74 Hz
(1) MAXTOR STM3200820A ATA Device (2) ST31000524AS ATA Device
Emachines
Logitech cordless
Hamster on a treadmill
Did the drivers install from Windows update?
I've owned a couple of recording PC's over the years with Audio cards such as M-Audio & RME Hammerfall.
The reason I ask is one machine was XP, and one was Windows 7, the XP machine worked like a dream. The Windows 7 machine gave me similar errors like you seem to be having.
I take it you've tried this link already, but in case you haven't.......
http://support.creative.com/kb/ShowArticle.aspx?sid=42331
Windows 7 Ultimate x64 SP1Intel Core i5-2500K (3300.0 MHz)8 GBytes (Dual-Channel)NVIDIA GeForce GT 440
Asus V-P8H67E
ASUSTeK Computer INC. V-P8H67E Rev 1.xx
NVIDIA High Definition Audio(4x)
Xerox XM7-20w
1ST Drive) Toshiba DT01ACA050
2ND Drive) WDC WD500AVDS-63U7B1
G7 Power Extreme 680W
Asus
Case fan, CPU fan
Zalman KG-400G
Logitech G300
12 Mbps
Disk1 Eset Smart Security 6/Disk2 AVG Internet security 2014
Mozilla Firefox
thanks for the reply and link sparks72
I do not believe I have read that one yet
Will go now
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
I cannot remember IF I uninstalled the old application and drivers for the on-board previous card.
Maybe this is my problem
Device manager shows 3 drivers :o
gonna try uninstalling everything and a fresh re-install
thanks for the info :thumbsup:
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
Good luck RNRP, let me know how it goes. :0)
Asus V-P8H67E
Xerox XM7-20w
Asus
Case fan, CPU fan
Zalman KG-400G
Logitech G300
12 Mbps
Mozilla Firefox
I am in a big mess now!
NEED HELP
It keeps saying setup cannot detect an installed product
it will now exit :cry:
grrrr
what a mess
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
Don't panic. Do you have any yellow exclamation marks in device manager?
The drivers for the sound card, are they from the original installation disk, if so then I suggest going to the manufacturers website to see if the drivers have been updated.
http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=205&prodID=10653&prodName=Audigy%202%20Value&subCatName=Audigy&CatName=Sound+Blaster&VARSET=prodfaq:PRODFAQ_10653,VARSET=CategoryID:1
Asus V-P8H67E
Xerox XM7-20w
Asus
Case fan, CPU fan
Zalman KG-400G
Logitech G300
12 Mbps
Mozilla Firefox
I did the above SEVERAL times
No yellow exclamation marks
Unfortunately the original installation disc got damaged beyond use,I have the updated driver info and files in a .rar file
This coupled with a current crash problem MAKES me want to panic
lol :D
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
lol :D
OK, remove all Creative drivers using device manager and download drivers from the link I gave you above. (If that's the correct card of course) Make sure you select ' Windows 7 x64' drivers.
I know many Creative card users have burst blood vessels over this problem, remain calm, you'll sort it. ;)
Asus V-P8H67E
Xerox XM7-20w
Asus
Case fan, CPU fan
Zalman KG-400G
Logitech G300
12 Mbps
Mozilla Firefox
I already removed all sound drivers and files etc using device manager and drive sweeper
It is only showing 2 High Definition Device (the ones that Windows keeps auto installing) in device manager
Creative Sound Blaster Audigy series driver 2.18.0017
Is the one I am trying to install :)
Yes I have read some forums/posts on it
I'm kool
lol
for now....:roflmao:
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
You can try this if Windows is auto installing drivers.
  1. Go to Start–>Search type in gpedit.msc
  2. Click the file to open the Local Group Policy Editor and show Windows who is in control!!
  3. You want to go here: Computer Configuration->Administrative Templates->System->Device Installation. Click on the sub folder Device Installation on the left and on the right side you will see the possible restrictions.
  4. Right Click on Prevent Installation of Devices not described by other policy settings and edit this option, set it on ENABLED.
  5. Reboot Windows and enjoy its inability to pollute your system with its standard driver, open gpedit.msc again and revert the change so you will be able to install your driver.
Asus V-P8H67E
Xerox XM7-20w
Asus
Case fan, CPU fan
Zalman KG-400G
Logitech G300
12 Mbps
Mozilla Firefox
when I type in gpedit.msc
I get the proverbial no item match your search
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
The Group Policy Editor, gpedit.msc, is NOT available in W7 Home Premium.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
right on
thanks Dwarf!
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
That's kicked that idea in the head then........
Asus V-P8H67E
Xerox XM7-20w
Asus
Case fan, CPU fan
Zalman KG-400G
Logitech G300
12 Mbps
Mozilla Firefox
whoops :p
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
I really don't know what to suggest apart form removing all Creative drivers and reinstalling from scratch.
Asus V-P8H67E
Xerox XM7-20w
Asus
Case fan, CPU fan
Zalman KG-400G
Logitech G300
12 Mbps
Mozilla Firefox
it has completely stopped working now
and will not even recognize the card
i have even did a fresh re-install of my whole system and re-seated the sound card
i am at a loss.....:confused:
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
I guess I need to figure out how to tell if the card has gone bad....gonna try n re-seat it...AGAIN :rolleyes:
Custom built
4.00 GB
ATI Radeon HD 4250
22" Envision
Emachines
Logitech cordless
Try this link............
http://www.askdavetaylor.com/how_to_diagnose_fix_sound_problems_windows_7_pc.html
If you don't have any luck with that, try this instead......
http://www.passmark.com/products/soundcheck.htm
Asus V-P8H67E
Xerox XM7-20w
Asus
Case fan, CPU fan
Zalman KG-400G
Logitech G300
12 Mbps
Mozilla Firefox
