Creative Sound card problems
  1. Posts : 50
    You can try this if Windows is auto installing drivers.
    1. Go to Start–>Search type in gpedit.msc
    2. Click the file to open the Local Group Policy Editor and show Windows who is in control!!
    3. You want to go here: Computer Configuration->Administrative Templates->System->Device Installation. Click on the sub folder Device Installation on the left and on the right side you will see the possible restrictions.
    4. Right Click on Prevent Installation of Devices not described by other policy settings and edit this option, set it on ENABLED.
    5. Reboot Windows and enjoy its inability to pollute your system with its standard driver, open gpedit.msc again and revert the change so you will be able to install your driver.
  2. Posts : 46
       #12
    when I type in gpedit.msc
    I get the proverbial no item match your search
  3. Posts : 9,582
    Windows 8.1 Pro RTM x64
    The Group Policy Editor, gpedit.msc, is NOT available in W7 Home Premium.
  4. Posts : 46
       #14
    right on
    thanks Dwarf!
  5. Posts : 50
    That's kicked that idea in the head then........
  6. Posts : 46
       #16
    whoops
  7. Posts : 50
    I really don't know what to suggest apart form removing all Creative drivers and reinstalling from scratch.
  8. Posts : 46
       #18
    it has completely stopped working now
    and will not even recognize the card
    i have even did a fresh re-install of my whole system and re-seated the sound card
    i am at a loss.....
  9. Posts : 46
       #19
    I guess I need to figure out how to tell if the card has gone bad....gonna try n re-seat it...AGAIN
  10. Posts : 50
    Try this link............
    http://www.askdavetaylor.com/how_to_diagnose_fix_sound_problems_windows_7_pc.html
    If you don't have any luck with that, try this instead......
    http://www.passmark.com/products/soundcheck.htm
