Windows 7: Laptop to TV Audio not working-Using Y adapter
29 Jan 2013   #1
mattster15
Windows 7 Home Premium 64bit.
Hey, So I want to be able to watch videos and stuff by streaming them from my laptop to my tv. I bought a VGA cable and I have the video working. For the audio I bought a Y-Adapter, and that is not working. I hooked the single end into the headphone jack on my computer, and I hooked the white and red ends into the white and red ports on the back of my tv, but still I'm getting no sound. Am I doing something wrong, or do I need to change the settings on my PC to make it work?
I am running: Windows 7 Home Premium
Acer
Aspire V3-571
29 Jan 2013   #2
Pauly
Win7 Ultimate X64
You will prob find the audio inputs on your telly also have a yellow video plug and will be assigned something like AV-2 or AV-3 but you have selected the vga port to display so it wont look at av input to output audio
29 Jan 2013   #3
bassfisher6522
Windows 7 Ultimate 64 bit
Does your laptop have an HDMI port? After checking your specs for it, it does. Why not use an HDMI cable...$20 and it's designed to that, carry video and sound.
29 Jan 2013   #4
mattster15
My TV isn't the greatest, it's LCD but it doesn't have an HDMI port, only a VGA port.
29 Jan 2013   #5
mattster15
Pauly are you saying that it's not possible for me to get video and audio then or?
30 Jan 2013   #6
Pauly
Win7 Ultimate X64
Not sure depends what outputs you have on pc and inputs on tv, generally hdmi is the easiest as bassfisher pointed out
If you have an input on your tv that takes audio and video you may be able to get a converter/adapter lead to get it to work ??
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Audio adapter failure, recognizes headphones that are not attached
I have a Dell XPS series which has a problem with its audio adapter. It detects a device attached nevertheless the device is not attached, because it says that it is attached the speakers of my laptop don't make a sound. Can somebody help me with this and see if it is either a hardware or...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
Quality of Smart phone audio vs standard LAPTOP PC audio
Hi there the newer smart phones have nice powerful processors in them so I was wondering if the DAC (Digital / Analog converters) in these are as good as the ones in a typical LAPTOP computer set up -- bog standard on board sound from a laptop computer -- not high end specialized studio stuff etc....
Laptop screen not working, audio buzzing
Hi, I have been using for a while a Toshiba Satellite c650 laptop. It has been used only to listen to music and to check e-mail via Internet Explorer. Recently, after a short camping trip where rain was abundant, the screen stopped functioning. The computer was working, we could hear the music...
General Discussion
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
