| Windows 7: Realtek Audio Jack Output Assignment Troubleshooting |
08 Feb 2013
#1 | | Windows 7 Professional 64 Bit Italy |
Realtek Audio Jack Output Assignment Troubleshooting The jack outputs are all bundled into one device. I want to have one device for each output jack, and not all on one. That means to automatically have detected various output devices...I add also a pic, so you can understand my problem. The picture text is in italian, but it shouldn't be a problem
Thanks for helping | My System Specs |
| OS Windows 7 Professional 64 Bit |
08 Feb 2013
#2 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
1. I see you have the "High Definition Audio" as the device type. That suggests that you do not have the RealTek sound driver installed. Instead just the basic function Microsoft/Windows sound driver.
I have RealTek and I have a RealTek HD Audio Manager that will allow SOME (not all) jack assignment changes.
You can only have one default audio playback device and if I understand you correctly, you can't have different devices for different outputs. You can have "Stereo" (2 channel) or 2.1 speaker system that is connected to the Green speaker jack. OR you could have a 5.1 speaker system with the the THREE connections to the PC. But, you can't have one jack for one device or speaker system and another for a different speaker system. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
128GB OCZ Vertex 4 SSD for Win 8
1 TB Seagate drive for backup Internet Speed 40 MB/sec (Cable) Antivirus Microsoft Security Essentials and Malwarebytes Browser I.E9/Firefox Other Info Sonar X2 Professional 64 bit Recording Software with Roland Octa-Capture and MAudio Fast Track Ultra 8R recording interfaces, Frontier Tranzport wireless control unit, Behringer BCF2000 Control Surface.
Five USB connected optical drives for CD Audio production using Nero 11
Other systems: Desktop with i5 3550 CPU, LenovoZ560 Laptop with Win 7 64 bit HP, SP1, new iPad |
08 Feb 2013
#3 | | Windows 7 Professional 64 Bit Italy |
Ok, but this is possible with RealTek? I mean, to have these outputs on different devices? | My System Specs | | OS Windows 7 Professional 64 Bit |
08 Feb 2013
#4 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
You can not have both analog and digital outputs active at the same time. You can have Analog (Speakers) or Digital only.
You can run stereo (2 channel) to whatever is connected to the GREEN speaker jack and also some other device connected to the LINE OUT, but they will both have the same PC audio - you can't have one audio, such as Youtube to the speaker out and a different PC audio, such as a game, to the Line out. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
08 Feb 2013
#5 | | Windows 7 Professional 64 Bit Italy |
No, I meant something different... I want to have the rear green output for my pc sound system. And I want to have another device listed if I plug in something at front green... So I would have my "Hitachi Amplifier" on rear green and my "Sennheiser headphones" (for example) on front green, but listed as two different devices... And so on for every jack output...
That means, that additionally to my Hitachi HA - 22 I would find a second device | My System Specs | | OS Windows 7 Professional 64 Bit |
08 Feb 2013
#6 | | Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit Citrus Co, FL |
The RealTek HD Audio Manager will do that. But, You must have the RealTek sound drivers installed, and as I originally noted it looks like you just have the basic Windows installed HD Audio Codec.
Go to your PC vendor and download the correct RealTek drivers. That should also install the RealTek HD Audio Manager.
Here is my RealTek and what I think you want to do. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number My Own Build OS Windows 7, 64 bit Home SP1, Win 8 Pro 64 bit CPU Intel i7 3770 Motherboard Gigabyte GA-Z77X-UD5H Memory 16GB GSkill Ripsaw F3-14900CL9Q-16GBXL Graphics Card Sapphire HD7770 Sound Card RealTek Monitor(s) Displays Viewsonic VA2448 Series 24" LED Screen Resolution 1920X1080 Keyboard Kensington wired Mouse Logitech Wireless PSU Antec High Current Gamer HCG-620M Modular Case Coolermaster HAF XM Cooling Corsair H80 Liquid cooling with aftermarket Nexus quiet fans Hard Drives 240GB Intel 520 SSD for Win 7
10 Feb 2013
#7 | | Windows 7 Professional 64 Bit Italy |
yeah, you're almost right about how I wanted the setting... On the pic you can see the option "Separate all input jacks as independent input devices". I know from my work-pc, that it is also possible with the basic windows audio codec to tick this option even for output devices. but, oddly, it does not work on my home-pc...
I will download the realtek and try to solve the issue...
thanks for your help | My System Specs | | OS Windows 7 Professional 64 Bit Realtek Audio Jack Output Assignment Troubleshooting problems? All times are GMT -5. The time now is 02:26 PM. | |
