re a problem with unpluging and pluging in the headphones
  1. Posts : 326
    windows 7 home 32 bit, I just changed back from 64 to 32bit
    I have a Gateway model MD2614U laptop os Win7 home 32bit. When I unplug the headphones to use the internal speakers sometimes the laptop will switch over and sometimes it won't. When it won't switch over. I open the volumes control window and I can see the green bar going up and down with the audio source but there is no sound coming out. I have to end up closing down the program that is producing the sound then the switch over will complete and I restart the program. I also have the same problem when I plug the headphones back in, again no sound from the headphones even though I see the green bar moving. Also some programs that send and receive audio over the internet will lock up when I unplug or plug in ether the headphones and or the microphone. Does anyone have any ideas on this problem?
  2. Posts : 14,606
    right click the speaker icon on the taskbar and select playback devices,
    when you see the headphones with the green bar, try setting them as default .
    (click on them to highlight them and then click set default then click apply then OK)
    hopefully when you unplug them your sound will revert back.
