re a problem with unpluging and pluging in the headphones
reble
12:37 PM
Kennewick, Wa
I have a Gateway model MD2614U laptop os Win7 home 32bit. When I unplug the headphones to use the internal speakers sometimes the laptop will switch over and sometimes it won't. When it won't switch over. I open the volumes control window and I can see the green bar going up and down with the audio source but there is no sound coming out. I have to end up closing down the program that is producing the sound then the switch over will complete and I restart the program. I also have the same problem when I plug the headphones back in, again no sound from the headphones even though I see the green bar moving. Also some programs that send and receive audio over the internet will lock up when I unplug or plug in ether the headphones and or the microphone. Does anyone have any ideas on this problem?
windows 7 home 32 bit, I just changed back fr...amc a6-6310, radon r4 graphics 1800mhz with 4...6.8gbnot sure off hand
Dell Inspiron 3541
windows 7 home 32 bit, I just changed back from 64 to 32bit
amc a6-6310, radon r4 graphics 1800mhz with 4 cores
6.8gb
not sure off hand
not shure off hand
built in lcd
1366 x 768
1 500gb sata internal HDD and 1 250 gb's sata HDD in a USB external USB case.
Wifi with attached wifi mouse
don't know
Zone Alarm
The gateway laptop model MD2614U died because a voltage regulator on the motherboard went poof. The Gateway laptop has been scraped.
right click the speaker icon on the taskbar and select playback devices,
when you see the headphones with the green bar, try setting them as default .
(click on them to highlight them and then click set default then click apply then OK)
hopefully when you unplug them your sound will revert back.
Hewlett packard/p6512uk
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
