Windows 7 sound card problems
  1. Posts : 5
    I have two microphones in the sound card after I have installed facebook video call app.
    The second microphone is always closed and I have to manually unmute the speaker/sound.
    It is always muted even when I unmute this and close the micorphone and sound card.
    How do I resolve this problem?
    Attached Thumbnails Attached Thumbnails Windows 7 sound card problems-facebook-video-call-app.png
  2. Posts : 6,879
    Win 7 Ultimate x64
    word20 welcome to the Seven Forums.
    One thing that would likely help would be to install the proper drivers for your sound, either onboard or actual card as it is currently running on the default Windows audio driver. The default driver does work to a point. It allows you to have sound (not necessarily very good sound) and not much else.
    Unfortunately can't point you in the right direction as to which you need as you didn't post any system specs.
  3. Posts : 5
    I have Windows 7 professional 64-bit sp1
    intel gradfic card
    Genuine intel(R) CPU U7300 @ 1.30 GHz 1.30 GHz Intel Oore Duo
    Is it more spec information that you need about the hardware?
    Attached Thumbnails Attached Thumbnails Windows 7 sound card problems-sound-card.png
  4. Posts : 5
    Hi
    I have Windows 7 Professional 64-bit Intel Core Duo 1.30 Ghz.
    Is it more spec information that you need?
  5. Posts : 8,135
    That does not answer Stormy's question. The PC vendor and model number if its a factory built system. If its a custom built, the motherboard vendor and model number will help to try and track down what audio you have.
  6. Posts : 5
    It is a laptop.
    Asus ul30a 13.3 "
  7. Posts : 8,135
    The sound is RealTek. The driver can be downloaded HERE from Asus
  8. Posts : 6,879
    Win 7 Ultimate x64
    ASUS - Notebooks- ASUS UL30A
    You need the Realtek audio driver, which is the forst one listed yn that screen shot. You will also likely need the Intel VGA driver for the second, as it is for HDMI audio.
