Editing the sound in Control panel
Page 2 of 2 FirstFirst 12
  1. Posts : 1,476
    meebers said:
    TwoCables said:
    Oh, be careful when using Registry Cleaners. They have a history of deleting false positives and sometimes breaking practically everything.
    I know, took precautions, did an image back up of the whole drive before "tweaking"
    Oh! :)
  2. Posts : 72,046
       #12
    meebers,
    In addition, double check in the registry location in OPTION TWO below to see if there may be an entry for "Avast" and it's sounds events.
    HKEY_CURRENT_USER\AppEvents\Schemes\Apps
    Sounds - Change
    If so, post a screenshot showing it for us to verify first, but deleting the registry key for it should remove it if there.
  3. Posts : 327
    Windows 7 Professional X64 Service Pack 1
    Brink said:
    meebers,
    Sounds - Change
    Ok here is the shot!
    Attached Thumbnails Attached Thumbnails Editing the sound in Control panel-avast.jpg
  4. Posts : 72,046
       #14
    Yep, that's the culprit.
    Delete the Avast key in your screenshot, and that'll remove it. You may or may not need to log off and log on to apply.
  5. Posts : 1,476
       #15
    You may need to Log Off and Log On in order for the Registry change to take effect (or just restart, whichever you prefer).
  6. Posts : 327
       #16
    Holy Crap-o-lee!! that did it. You get extra points for that one... Did not have to log off/on. Thank you very much!
  7. Posts : 72,046
       #17
    Great news. You're most welcome. :)
