Windows 7: Microphone output very low or hissing noise when mic plugged in
24 Feb 2013   #1
I've been having problems with my microphone on a Windows 7 desktop: very low volume and hissing feedback. Googling this problem it seems that it's a very common one. My mic worked fine on a Windows 7 laptop (good volume, no hissing) so the mic itself was OK.
I found the following article which solved the problem:
Resolving Microphone and Line-in Problems (Windows*7) | HP® Support
What I didn't realize is that the Playback properties levels have to be set. Once I changed these everything was fine.
The article is also a very good general trouble-shooting guide for Windows audio. I would highly recommend it.
BTW: this is an HP / Compaq article, but it applies to any Windows PC with Realtek audio (and maybe to others??). My desktop is a custom-build with an Intel DP64BG motherboard.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
