Windows 7: Headphone test OK but no sound
27 Feb 2013   #1
OldLou06488
Windows 7 Home Premium 64 bit
I used Dell Laptop, Windows 7 64 bit every day.
I am 83 and like a bigger screen with better color.
My normal hookup is HDMI out from my laptop and in to 19" Vizio
I never got audio through HDMI out.
I used headphones, stereo from the #1 stereo jack, audio OK
For 3 or 4 months I bought Sonawave USB Stereo clip on speaker, great.
When I get up early AM, between 4 and 5, I switch to headphone not to disturb wife
Yesterday I could not hear any audio from headphones.
I do get audio for USB
Corrective action tried and failed
Verified default setting via Control Panel and test
Audio displayed but not heard on headphone
Audio displayed and heard on the USB Sonawave
Today I used Norton 360 to check register.
It cleaned some problems but still no headphone sound
I plugged same headset into my Vizio HDTV and sound is working
Any suggestions, I am more of a user than a tech.
Thank you
27 Feb 2013   #2
Saurabh A
Windows 7 64bit
Hi OldLou06488,
If I understand correctly, you are experiencing two issues with 'Audio Playback':
Issue 1
Issue 2: Not Getting Audio playback with 'Headphones and USB Speakers' (Was functional before)
You may find the steps listed below helpful:
1. Since you are experiencing audio issues with multiple 'audio devices' (Headphones, Speakers, USB, etc), it is unlikely that the power and volume settings on the 'devices' could be the root cause. Please check the 'Volume settings' in 'Windows' to ensure that it is properly configured.
- Open 'Volume Mixer' by clicking the 'Start icon' > 'Control Panel' > 'Hardware and Sound' > Underneath 'Sound', click 'Adjust system volume' > Move the slider upwards to increase the 'volume'.
- Also ensure that the 'Mute button' isn't turned on. If yes, click it to 'turn off muting'.
2. Configure the 'Sound Settings' on the notebook:
- Use key combination '<Fn><Page Up>' to increases the 'volume' of 'integrated speakers and external speakers', if attached.
- Key Combination <Fn><End> is used to 'Enable/disable' the 'integrated speakers and external speakers'. Please tap them to verify if the 'laptop sound' is disabled.
3. If the issue persists, open 'Device Manager' to check if the 'Audio Drivers' are in a 'healthy state'; and try re-installing them:
- Click 'Start' > Type 'devmgmt.msc' (without quotations) in 'Search box > Tap 'Enter' > Locate and Expand 'Sound, Video & Game Controllers' category > Check any listed device has a mark (exclamation or question mark) besides it > If yes, capture & share the details.
- Inspiron 1525 is built with 'Sigmatel stac9228x' audio. It is tested to work with 'Windows XP & Vista'; therefore 'Windows 7' compatible drivers for its 'devices' are not listed on 'Dell Support Website'. However, it is likely that Vista tested drivers may also work. Try re-installing the 'audio drivers' and check results.
- To re-install, Open 'Deive Manager' > Right click the 'Sigmatel related driver' under 'Sound, Audio & Game Controllers' category > 'Un-install' it > Follow through to complete the un-install process > Restart the system and try installing the following 'audio driver' in 'Vista compatibility mode': Driver Details | Dell India (Please refer to the tutorial for assistance on installing drivers in compatibility mode: Drivers - Install Vista Drivers on Windows 7)
Hope this helps. Once the notebook sound gets working, will try to get the 'LCD audio' through 'HDMI' working as well.
Do reply with the findings;
28 Feb 2013   #3
OldLou06488
Thank you
Thank you Saurabh A. Headphone and speakers audio fixed.
28 Feb 2013   #4
Saurabh A
Windows 7 64bit
Hi OldLou06488,
Glad that the 'audio' is restored; thank you for confirming.
Would like to know if the 'audio drivers' were bad or the sound was 'disabled' in the Notebook/Windows.
28 Feb 2013   #5
OldLou06488
Undefined Fix
I did not replace any driver. All the volume sliders seemed OK. As I clicked above sliders and returned to test the sound, it was there, both system sound and headphone sound.
01 Mar 2013   #6
Saurabh A
Windows 7 64bit
Hi OldLou06488,
Thank you for the response.
The audio drivers were in good shape. It appears that the notebook sound was disabled. Glad, its up & running.
Do reply if you need any further assistance; glad to help.
Sound coming from both headphone & speaker but headphone is not detect
I have Lenovo 3000 Y410 laptop having Windows 7 Home Premium installed on it. Realtek HD Audio latest driver is installed. But from the last 3 days, when I connect headphone through laptop, following things happen : - 1) Headphone connected popup doesn't show up. 2) Mic of Headphone connected pop...
No sound from right headphone-hp pavilion dv6
Any headphones I plug in to either of the two ports, the right headphone doesnt work. i tried with different headphones none of them work ( new or old ones.) when i try plug the headphones on others pc and laptop,both right and left side is working fine external speakers work well. sound...
HP laptop no sound from speaker but there is sound through headphone
My wife HP Pavilion DV6175ea laptop running windows 7 ultimate 32 bits was fine with the sound until a month ago. Note that upgraded from vista since the windows 7 launch. From that date till now it as no sound from the speakers but it is ok from the headphones. Tried different audio drivers but...
No Sound From Front Headphone Jack
Hi, When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500. The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't....
No sound in Microsoft Headphone
I'm using natural reader 9.5 it was perfectly, I could hear it through my USB attached Microsoft life chat Lx-3000. Now instead of hearing a sound from my default device (Microsoft life chat Lx-3000) natural reader is emitting sound from my speakers. I have attached the screenshots. OMG...
I have hp dv1738od and have upgraded to Windows 7, previously Windows XP. Everything seem to be working ok except, for the sound. Window 7 automatically installed the driver, and said the sound card was working properly. But there was no sound through speaker. I removed the driver and reinstall...
