Windows 7: Audio drivers problem
02 Mar 2013   #1
aironhight
windows 7 ultimate x64
Hallo!I have a problem with my audio-I was using via hd audio program(i dont know if its called driver or w/e) and i was getting some audio effects (echo) and when i turned them off the automaticly turned on so i uninstalled the program and now i dont have audio.Please tell me which program should I install and if you can please give me a link.My motherboard is Asrock i dont know any models or information about it if you need it please tell me how to find that information.Thank you!
03 Mar 2013   #2
Saurabh A
Windows 7 64bit
Hi aironhight,
It appears that the removal/corruption of 'audio drivers' have lead to the loss of 'audio'. Since we are not sure about what exactly happened, you may try a complete 'audio driver' re-installation to see if that helps.
To check the status (and remove) the 'system audio', please open 'Device Manager'. Please refer to the steps listed below:
- Click 'Start' > Type 'devmgmt.msc' (without quotations) in the 'Search Box' > Tap 'Enter' (Device Manager appears) > Locate and Expand 'Sound, Video & Game Controllers' (Sound Card drivers are listed under this category) > Check if a 'question mark/exclamation mark' is observed besides any 'device' (You may also look through the whole list to see if any other device is listed with such a mark, under 'Other Devices')
Right click the 'Audio Device' > Click 'Properties' > Click 'Details' tab > Select 'Hardware ID' from the 'Property Drop Down' > Capture and share 'Hardware ID details'. (Refer to this article: Hardware Identification)
You may then right click and uninstall that device driver. Follow the on-screen instructions to complete removal. Restart the system and install fresh 'audio drivers' from the manufacturer website. If not sure, please share the 'Hardware Id' details of the 'device' and I will help you with the appropriate driver for the card installed in your computer.
Hope this helps. Do reply if you have any further questions; would be glad to assist.
Problem with audio & graphics Drivers
Hello guys , i have this problem i make a full reinstall of the windows on my computer cuz i was ahveing some probelms with my Lan card . Anyways after i format the disc and i install the windows ( Win 7 ultimate x64) i put the drivers of my motherboard (P7p55d le ) and my Graphic card ( ATI...
Drivers
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Problem with creative audio drivers installing .
I am getting weird errors while installing the drivers LIke > 1.( Installation is unable to continue because of one or more unresloved issues. Please contact support services and quote error I/001) Sound Card> Creative Sound Blaster X-Fi Titanium 7.1 Sound Card (70SB088000000) OS> windows...
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
problem with audio drivers on win 7
hi. i have problem whit some audio drivers because my pc is old... i dont can find driver for http://bildites.lv/images/xnb5wbcc8f37u7xruynk.jpg this two devices... mby someone can help me? :(
Drivers
