Windows 7: Sound card advice
11 Mar 2013   #1
flappa
Windows 7 64 bit
Sound card advice
Hi, i have the Logitech Speaker System Z313 (was sent as replacement for my old one) but it does not have Bass controls on it, so i was wondering if i got a sound card could i control the bass through that ?
Also
If i got a sound card is there anyway i can control voices in movies ? i tend to watch a lot of movies late at night, and am having to constantly turn the volume up and down
Thanks.
11 Mar 2013   #2
bobkn
Windows 7 Pro X64 SP1
What are you using for sound now? Good onboard sound (Realtek) has some of the features of a discrete sound card.
I recently got a Sound Blaster Z card. I believe that it has the features that you're asking about. I haven't exercised them yet, because I live alone in a "single family" house. There's no need for me to limit the volume at night. I mostly watch movies on an LCD TV, anyway.
The Z may be a bit expensive for your needs. Amazon UK has it for around 80.
12 Mar 2013   #3
ICIT2LOL
Personally I put the Asus Xonar DG in my machines mate not expensive and you have a really nice GUI to play around with the sounds.
Plus you can use 2:1 up to 7:1 systems with it move the speakers around etc etc
ASUS - Xonar DG
12 Mar 2013   #4
Rockfella
Windows 8.1 Pro
ASUS DG to begin with DX for bet bang for buck in the entire world. For the feature you want i'm sure there must be some softwares which can do that. My DX can control bass but not automatic volume control.
12 Mar 2013   #5
ICIT2LOL
Quote   Quote: Originally Posted by Rockfella View Post
Absolutely Rockfella I think that one is brilliant but for what I wanted and at the price the DG is just fine.
I can control all frequencies and the effects that I want but what I don't get is why would you want automatic volume control?? I have that in my Mazda's Bose system and can see the point but in a computer I am a bit perplexed.
12 Mar 2013   #6
flappa
Windows 7 64 bit
cheers for the info guys, will look this card up
 Sound card advice
factory sound card VS SoundBlaster USB sound card
hello in my present setup i have a factory soundcard thats installed in my intel atom mini pc and i have a usb soundblaster laying around.. my question is it worth to swapp in the usb sound card or its not much of a difference using the built in sound card my PC Cheap Intel Atom Mini Pc Hi10c...
Does anyone have advice for using an external sound card?
I was thinking of trying one to see if the sound garbling problem I experience would be alleviated with an external sound card.
external sound card advice for use with monitor speakers
Hi Basically i've just got my new laptop this week, had desktop pc's for nearly 10 yrs with internal sound card to power a 5.1 surround system now ive ordered some krk rokik rp5 g2 monitor speakers but i want to be able to play music from laptop with media player etc, through the monitor...
Just looking for some sound card advice and suggestions
Hi, I just got a new computer, Intel I7 2600 processor, 8 gb ram, nvidea 550TI, MSIp67a-c43 motherboard and have 3 pcix1 express slots and 3 regular pci slots available. There are no PCI expressx16 slots available. Windows 7 home premium. I currently have an integrated sound on the motherboard,...
FPS drop because of sound card / sound card drivers?
I've recently upgraded my os to windows 7, and noticed a significant fps drop in all games I've installed. The problem seems to come from the sound card. I've disabled it in device manager and I gained a steady 15-20 more in most of the applications. Any idea what to do? Is it a driver issue or...
Gaming
Sound Card Advice
I'm going from XP 32 bit to Win7 64 bit any advice on which sound card to buy (no vista 64 bit drivers for my old X-Fi Fidelity card)
