How to stop volume of background applications from lowering...
  1. Posts : 23
    Windows 7 Ultimate 32-bit
    How do I stop volume of background applications from lowering when I play a game?
    Whenever I start a skype call or want to play a game with voice chat, the volume of background applications instantly drops by a significant amount. This is annoying because I want to listen to music while I game and it's just not possible like this.
    A quick Google search suggests that this is a common Windows 7 "feature":
    audio - Windows 7 lowers applications' volume automatically - Super User
    I have applied the fix suggested in the article (Change settings to "do Nothing" when Windows detects communication activity) but this did not work. Any ideas why? I am running a Thinkpad T530 laptop and I have a Realtek sound card.
  2. Posts : 309
    Since you have already changed your sound setting to "do nothing" open up Skype and disable both settings in Skype under tools->sound settings, that says "let Skype configure your microphone" & "automaticly change speaker settings" to my knowledge that should work
  3. Posts : 25,847
    In my opinion you are just asking a ASUS X82S to do more than it is designed to do at one time.
  4. Posts : 220
    Windows 7 Pro x64
    I'm curious if disabling the Exclusive Mode options under the Advanced Speaker Settings will do anything:
  5. Posts : 4,161
    Windows 7 Pro-x64
    That's the other setting Bullet. Good catch!
  6. Posts : 23
    I have applied both settings but still my volume is lowering. I get this in games too (like Dota 2, TF2), not just Skype so I don't think it's a Skype setting. I'm also using a Thinkpad T530, not an Asus X82S.
    if i disable my microphone, volume levels are as they should be without being suppressed. However I don't want to do this every time I want to play a game. Help would be appreciated. :)
  7. Posts : 1
    Win7
    Same issue diff comp.
    I have this issue on an HP Compaq 6200 Pro. On Win7. I've tried "do nothing" for the communications settings. (See prt screen) I have the check boxes unchecked in Headset Earphone Properties. (see print screen)
    Skype Audio Settings. (see attachment).
    I've read posts that say Nvidia does it.
    I don't think I have that I have Realtek. (See attachment.)
    I'm assuming it's Jabra...
    Attached Thumbnails Attached Thumbnails How to stop volume of background applications from lowering...-sound-video-game.png   How to stop volume of background applications from lowering...-sound-communications-80.png   How to stop volume of background applications from lowering...-headset-earphone-properties.png   How to stop volume of background applications from lowering...-skype-audio-settings.png
