6 months now and still no solution to audio Crackling/Popping/Dropouts
Page 2 of 7 FirstFirst 1234 ... LastLast
  1. Posts : 21,004
    fireberd said:
    The ASIO4ALL may be causing the non detection of the sound hardware and why the proper Dell driver will not install.
    You may have to install the Intel motherboard chipset drivers first and then the IDT sound driver.
    I also go for the manufacturers sites for any drivers wherever possible
  2. Posts : 104
    7/64 bit
       #12
    I reinstalled all of the drivers.
    Still no change.
    Does not anyone else have any suggestions?
  3. Posts : 21,004
    Still no change.
    Hiyya Kwitel the only thing I can think of my friend that something is loose within the machine. I know Toshiba laptops have small ribbon cables attaching various components together so any bump or hard knock could have loosened something up like that.
    You haven't dropped or spilt anything on the machine have you?
    **To the previous member (lorrettshaw) post I don't think that is a very helpful comment to be making and in fact is not in the general interest or the accepted form of goodwill of this forum. Perhaps you might think it jovial but I am sure Kwitel needs help not jocularity if indeed if that was your intention??
  4. Posts : 104
    7/64 bit
       #14
    ICit2lol said:
    Still no change.
    Thank you.
    Im sure the previous poster meant it jokingly; I take no offense.
    Your point is well taken and I will definitely look into it.
    Is it Occams razor that states that the simplest answer is usually the correct one?
    I think I need to at least consider thinking a little more along those lines...
  5. Posts : 21,004
       #15
    Yes Kwitel myself I always go looking for simple stuff first as you are right as a general rule and we are all guilty of it - go looking for the most involved possibilities when in fact they don't exist.
    Now I am thinking do you have it hooked up to an after market sound system?? ie one that plugs in visa USB?? or even have something plugged in to a USB port that may be causing that crackling problem?
    As for the other post I am sure you took no offence but I just thought it was wasting time and frankly had no place in this thread. If there had been a possible solution offered and then a remark like are you sure you are not near the cooker and frying eggs then yes it might have been funny but on it's own - not funny. Don't get me wrong I have a very warped sense of humour and use it quite often but not in that fashion if you get my drift:)
  6. Posts : 104
    7/64 bit
       #16
    I do.
    I am listening through a Audio Advantage Micro.
    I know...I should have thought about this sooner...
    I will do some testing and see if this has been the culprit all along. Although it would be odd as when I disable my network adapters, the problems cease.
    Unless the AAM is somehow interfering with my network adapters or, vice-versa?
    With Windows I guess anything is possible.
  7. Posts : 21,004
       #17
    Well I must admit I have never seen this before and maybe just plugging in the sound system or phones without the device might work.
    Just out of interest what exactly is the difference it makes as I cannot quite work out how if there is two phone drivers how they could be made to sound surround?
    If it is just an effect well maybe worth buying a new one but we'll wait until you have doenwhat you have to do.
  8. Posts : 104
    7/64 bit
       #18
    Im sorry but I dont think i understand this question...
    That aside, Its not the audio device.
    I completely removed it from my system, and I still have the same problems.
    The problem creates: intermittent static, "pops" (that occasionally startle me they are so abrupt and annoying), "crackling" sounds (akin to a record player) and flat-out drop-outs in audio (never longer than 1 or 2 seconds).
    Both adapters cause problems although the land-line "seems" to be the culprit.
    When I disable both the problems go away (although i still experience some latency issues).
    Im lost.
    EDIT: I dont know if this helps, but my pops/crackles/latency issues occur when i do something on the computer (ie, open a window, close/open a program, etc). Basically any CPU usage prompts an audio issue.
    Maybe its related to throttling?
    My computer (and the whole Latitude line) has had/is notorious for throttling issues and over-heating.
  9. Posts : 21,004
       #19
    Sorry Kwitel I was assuming you were still using the device as I said I haven't come across it myself.
    Now you mention this happens whenever you use the machine ie prompting some response from the CPU.
    Now logic tells me that this involves some reaction / transfer / interaction between the CPU and the hard drive plus it would also require also some interaction with the memory.
    I am now thinking maybe the hard drive is not working as it should be or that the RAM sticks are siting loose in their slots. Because you have done all the drivers and whatever anyone else has suggested and have had no resolve.
    As for the CPU it could be that the thermal compound needs replacing or that the heat sink has come loose and allows some movement over the pins . I am just trying to eliminate any physical causes here.
    So as I can not find any mention of the age of the machine or what CPU is in it can you run Speccy and let us know what the temps are in the machine. It would be interesting to see what the CPU actually is and the specs and temps are in general.
    http://www.piriform.com/speccy/download < from piriform
    If you are able to can you reseat the RAM sticks too? Plus can you listen to the hard drive when it spins up it should be reasonably quiet with no loud clicks or rattling.
  10. Posts : 104
    7/64 bit
       #20
    By the way, thanks for your time with this.
    I downloaded Speccy; what a cool application!
    FYI-I am using a 256GB SSD. I havent even thought of the drivers for that...its listed as an "Unknown Manufacturer" in Speccy. I will have to open up my machine tomorrow to check for all of your physical-related points listed above.
    As for the CPU:
    Intel Mobile Core 2 Duo P9600
    Cores 2
    Threads 2
    Name Intel Mobile Core 2 Duo P9600
    Code Name Penryn
    Package Socket P (478)
    Technology 45nm
    Specification Intel Core2 Duo CPU P9600 @ 2.66GHz
    Family 6
    Extended Family 6
    Model 7
    Extended Model 17
    Stepping A
    Revision E0
    Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, Intel 64
    Virtualization Supported, Disabled
    Hyperthreading Not supported
    Bus Speed 260.8 MHz
    Rated Bus Speed 1043.1 MHz
    Stock Core Speed 2666 MHz
    Stock Bus Speed 266 MHz
    Average Temperature 48 °C
    Caches
    L1 Data Cache Size 2 x 32 KBytes
    L1 Instructions Cache Size 2 x 32 KBytes
    L2 Unified Cache Size 6144 KBytes
    Core 0
    Memory:
    RAM
    Memory slots
    Total memory slots 2
    Used memory slots 1
    Free memory slots 1
    Type DDR2
    Size 4096 MBytes
    Channels # Single
    CAS# Latency (CL) 6 clocks
    RAS# to CAS# Delay (tRCD) 6 clocks
    RAS# Precharge (tRP) 6 clocks
    Cycle Time (tRAS) 18 clocks
    Physical Memory
    Memory Usage 83 %
    Total Physical 3.95 GB
    Available Physical 660MB
    Total Virtual 7.90 GB
    Available Virtual 4.31 GB
    SPD
    Number Of SPD Modules 1
    Slot #1
    Overview:
    Operating System
    Microsoft Windows 7 Professional 64-bit SP1
    Intel Mobile Core 2 Duo P9600 @ 2.66GHz 47 °C
    Penryn 45nm Technology
    RAM
    4.00 GB Single-Channel DDR2 (6-6-6-18)
    Dell Inc. 0U692R (Microprocessor) 57 °C
    Graphics
    DELL P2211H (1920x1080@60Hz)
    Mobile Intel 4 Series Express Chipset Family
    238GB LITEONIT LAT-256M2S (SSD)
    Optical Drives
    HL-DT-ST DVD+-RW GSA-U20N
    Audio
    Audio Advantage Micro Device
