6 months now and still no solution to audio Crackling/Popping/Dropouts
kwitel
11:47 PM
Im desperate here as I simply cannot figure out the solution is and this thing is driving me nuts.
I have major latency issues and from DPC checker have figured out that its my network adapters (or at least I think).
When I disable both of them, I get nearly perfect sound.
Ive re installed them/dloaded new drivers multiple times and no difference.
Does anyone have any other suggestions?
I have a DELL E6400, Windows 7/64bit.
Any help is greatly appreciated.
7/64 bitIntel Core i-5-34704gbIntel HD Graphics-1920x1080
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
I know its no help but I have exactly the same problem with home built asus based PC, with tenda 802.11n W322P network card.
windows 8 Pro x64Intel Pentium 4 Prescott 90nm3.00GB Single-Channel DDR @ 199MHz (3-3-3-8)512MB ATI Radeon HD 3450 (AMD Computer Inc)
custom build
windows 8 Pro x64
ASUSTeK Computer Inc. P4C800-E (CPU 1)
SoundMAX Integrated Digital Audio
IPS235 (1440x900@59Hz)
1440x900@59Hz
75GB Maxtor 6V080E0 ATA Device (SATA)
466GB Hitachi HDP725050GLA360 ATA Device (SATA)
It drives me nuts.
And as an audiophile, it completely negates my headphones, amp, etc...
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
Anyone have any suggestions?
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
Windows 10x64 Build 1709Intel i7 7700HQ Kaby Lake16 GB DDR4 @2400Nvidia Geforce GTX 1060
MSI GE72VR Apache Pro-416
16 GB DDR4 @2400
1920x1080 120Hz
256 GB Nvme M.2 SSD
1TB HDD@7200
Cooler Blast 4
Steel Series
Bit Defender Free
Edge
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
Opening the drumming program to show you how/where to install. Watch again, and do it as he is.
16 GB DDR4 @2400
1920x1080 120Hz
256 GB Nvme M.2 SSD
1TB HDD@7200
Cooler Blast 4
Steel Series
Bit Defender Free
Edge
ASIO4ALL can be iffy - work on some installations and not or cause problems on others. I and others that I deal with on recording DAW forums have had mixed success with ASIO4ALL for devices that do not have ASIO drivers.
In regards to the popping/crackling, etc. There are many potential causes for that, there is no "one fix". Some items that have been known to cause this is Wi-Fi and as you have found out disabling fixes your problem. Sound drivers are another - make sure you are using the Dell supplied driver, as non-Dell drivers many times either do not work or do not work correctly. I did a lot of support on the Dell users forums (for 10 years and over 38,000 posts) and non-Dell sound drivers were a major source of sound problems. I no longer have a Dell product and didn't think it was appropriate for me to continue posting on that forum.
There is a "Jim" on the Dell Laptop forum that is very knowledgeable about Dell laptops and in particular sound issues. If you haven't posted on there, give it a try.
Laptop - Dell Community
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I went to the dell site and installed their driver but its said that "the hardware detected is not supported by this software package, the install will be aborted".
Its the IDT 9200 driver for my operating system; what do you think is going wrong here?
After this, my computer then just re installs the default drivers that I have on my system, which might be causing my problems.
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
The ASIO4ALL may be causing the non detection of the sound hardware and why the proper Dell driver will not install.
You may have to install the Intel motherboard chipset drivers first and then the IDT sound driver.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
:ditto: I also go for the manufacturers sites for any drivers wherever possible
1920x1080 D1 & D2 & Laptop 1
Desk1 Samsung 120GB 830 SSD
Asus ROG 256GB 850 Pro SSD
Desk2 Samsung 840 256 SSD
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
I reinstalled all of the drivers.
Still no change.
Does not anyone else have any suggestions?
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
Still no change.
Hiyya Kwitel the only thing I can think of my friend that something is loose within the machine. I know Toshiba laptops have small ribbon cables attaching various components together so any bump or hard knock could have loosened something up like that.
You haven't dropped or spilt anything on the machine have you?
**To the previous member (lorrettshaw) post I don't think that is a very helpful comment to be making and in fact is not in the general interest or the accepted form of goodwill of this forum. Perhaps you might think it jovial but I am sure Kwitel needs help not jocularity if indeed if that was your intention??:sarc:
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Still no change.
Thank you.
Im sure the previous poster meant it jokingly; I take no offense.
Your point is well taken and I will definitely look into it.
Is it Occams razor that states that the simplest answer is usually the correct one?
I think I need to at least consider thinking a little more along those lines...
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
Yes Kwitel myself I always go looking for simple stuff first as you are right as a general rule and we are all guilty of it - go looking for the most involved possibilities when in fact they don't exist.
Now I am thinking do you have it hooked up to an after market sound system?? ie one that plugs in visa USB?? or even have something plugged in to a USB port that may be causing that crackling problem?
As for the other post I am sure you took no offence but I just thought it was wasting time and frankly had no place in this thread. If there had been a possible solution offered and then a remark like are you sure you are not near the cooker and frying eggs then yes it might have been funny but on it's own - not funny. Don't get me wrong I have a very warped sense of humour and use it quite often but not in that fashion if you get my drift:)
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
I do.
I am listening through a Audio Advantage Micro.
I know...I should have thought about this sooner...
I will do some testing and see if this has been the culprit all along. Although it would be odd as when I disable my network adapters, the problems cease.
Unless the AAM is somehow interfering with my network adapters or, vice-versa?
With Windows I guess anything is possible.
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
Well I must admit I have never seen this before and maybe just plugging in the sound system or phones without the device might work.
Just out of interest what exactly is the difference it makes as I cannot quite work out how if there is two phone drivers how they could be made to sound surround?
If it is just an effect well maybe worth buying a new one but we'll wait until you have doenwhat you have to do.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Im sorry but I dont think i understand this question...
That aside, Its not the audio device.
I completely removed it from my system, and I still have the same problems.
The problem creates: intermittent static, "pops" (that occasionally startle me they are so abrupt and annoying), "crackling" sounds (akin to a record player) and flat-out drop-outs in audio (never longer than 1 or 2 seconds).
Both adapters cause problems although the land-line "seems" to be the culprit.
When I disable both the problems go away (although i still experience some latency issues).
Im lost.
EDIT: I dont know if this helps, but my pops/crackles/latency issues occur when i do something on the computer (ie, open a window, close/open a program, etc). Basically any CPU usage prompts an audio issue.
Maybe its related to throttling?
My computer (and the whole Latitude line) has had/is notorious for throttling issues and over-heating.
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
Sorry Kwitel I was assuming you were still using the device as I said I haven't come across it myself.
Now you mention this happens whenever you use the machine ie prompting some response from the CPU.
Now logic tells me that this involves some reaction / transfer / interaction between the CPU and the hard drive plus it would also require also some interaction with the memory.
I am now thinking maybe the hard drive is not working as it should be or that the RAM sticks are siting loose in their slots. Because you have done all the drivers and whatever anyone else has suggested and have had no resolve.
As for the CPU it could be that the thermal compound needs replacing or that the heat sink has come loose and allows some movement over the pins . I am just trying to eliminate any physical causes here.
So as I can not find any mention of the age of the machine or what CPU is in it can you run Speccy and let us know what the temps are in the machine. It would be interesting to see what the CPU actually is and the specs and temps are in general.
http://www.piriform.com/speccy/download < from piriform
If you are able to can you reseat the RAM sticks too? Plus can you listen to the hard drive when it spins up it should be reasonably quiet with no loud clicks or rattling.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
By the way, thanks for your time with this.
I downloaded Speccy; what a cool application!
FYI-I am using a 256GB SSD. I havent even thought of the drivers for that...its listed as an "Unknown Manufacturer" in Speccy. I will have to open up my machine tomorrow to check for all of your physical-related points listed above.
As for the CPU:
Intel Mobile Core 2 Duo P9600
Cores 2
Threads 2
Name Intel Mobile Core 2 Duo P9600
Code Name Penryn
Package Socket P (478)
Technology 45nm
Specification Intel Core2 Duo CPU P9600 @ 2.66GHz
Family 6
Extended Family 6
Model 7
Extended Model 17
Stepping A
Revision E0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, Intel 64
Virtualization Supported, Disabled
Hyperthreading Not supported
Bus Speed 260.8 MHz
Rated Bus Speed 1043.1 MHz
Stock Core Speed 2666 MHz
Stock Bus Speed 266 MHz
Average Temperature 48 °C
Caches
L1 Data Cache Size 2 x 32 KBytes
L1 Instructions Cache Size 2 x 32 KBytes
L2 Unified Cache Size 6144 KBytes
Core 0
Memory:
RAM
Memory slots
Total memory slots 2
Used memory slots 1
Free memory slots 1
Type DDR2
Size 4096 MBytes
Channels # Single
CAS# Latency (CL) 6 clocks
RAS# to CAS# Delay (tRCD) 6 clocks
RAS# Precharge (tRP) 6 clocks
Cycle Time (tRAS) 18 clocks
Physical Memory
Memory Usage 83 %
Total Physical 3.95 GB
Available Physical 660MB
Total Virtual 7.90 GB
Available Virtual 4.31 GB
SPD
Number Of SPD Modules 1
Slot #1
Overview:
Operating System
Microsoft Windows 7 Professional 64-bit SP1
Intel Mobile Core 2 Duo P9600 @ 2.66GHz 47 °C
Penryn 45nm Technology
RAM
4.00 GB Single-Channel DDR2 (6-6-6-18)
Dell Inc. 0U692R (Microprocessor) 57 °C
Graphics
DELL P2211H (1920x1080@60Hz)
Mobile Intel 4 Series Express Chipset Family
238GB LITEONIT LAT-256M2S (SSD)
Optical Drives
HL-DT-ST DVD+-RW GSA-U20N
Audio
Audio Advantage Micro Device
Dell E6400
7/64 bit
Intel Core i-5-3470
Dell-042P49
4gb
Intel Display Audio
Dell P2211H
19620*1080
Samsung SSD
WDC 1TB
