audio drop outs/skipping caused by 802.11n wireless network card?
thedoc735
2:27 AM
I have had my old pentium 4, for years.
I put windows 7 on it with more memory, upgraded GPU & added a wireless 802.11n network card.
I have tried the on board P4C8000 (asus) audio as well as 2 different sound cards from 'creative', but no matter what I do I get this audio interference and I suppose it resembles the popping and cracking of the static on a vinyl LP record when the styli hits the deck and spins!
I have tried several different tracks with different headphones and it is always the same!
Anyone got any ideas please?
PS: On any given recording, the sound is distorted, like if you record a cassette tape with the volume right up high causing saturation. However, all the faders (in windows) are set to about 50% max. as is my headset volume.
I've just noticed that when I play a high quality audio CD ROM (purchased, not downloaded poor quality internet junk) the interference seems to be in time with the transmission LED on the 802.11n network card. There are about six PCI slots on the back of the case but even when I put the network card at the very bottom and the sound card at the very top (slot) the network cards aerials are always within 6 inches of the headset cable and are often right between the aerials. Does anyone know if a local network can cause this to happen and is there a solution please? i.e. drop outs/skipping/stuttering etc?
windows 8 Pro x64Intel Pentium 4 Prescott 90nm3.00GB Single-Channel DDR @ 199MHz (3-3-3-8)512MB ATI Radeon HD 3450 (AMD Computer Inc)
custom build
windows 8 Pro x64
ASUSTeK Computer Inc. P4C800-E (CPU 1)
SoundMAX Integrated Digital Audio
IPS235 (1440x900@59Hz)
1440x900@59Hz
75GB Maxtor 6V080E0 ATA Device (SATA)
466GB Hitachi HDP725050GLA360 ATA Device (SATA)
Wi-Fi is a known cause of popping and crackling. If you must have a wireless connection have you tried disabling the wireless controller when you play audio? to verify that is the problem. That would be the first step in trying to resolve the problem.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
When the tenda W322P is disabled in windows 7 device manager the problem disappears completely
I don't think "ASIO4ALL" is any good for my Sound Blaster X-Fi Xtreme Audio (don't think ASIO is supported)?
custom build
windows 8 Pro x64
1440x900@59Hz
ASIO4ALL can have mixed results. Works on some sound devices and not others, and can even cause problems with some. All the SoundBlaster's that I've seen have ASIO drivers so ASIO4ALL is not needed with them.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
