Solved Disabling annoying system/folder "beep" sound
ACWN
Crazy Ferret Lady
Power User
4:17 PM
The desert
Okay, so, before anything else... I've already gone in and changed my system sounds. Everything but a handful of sounds (Device Connect/Disconnect, Email) have been turned off.
However, whenever I open a folder on my desktop and click anything within that folder - subfolder, back or forward button, the "address bar" (not sure what else to call it - its the bar where your system/folder location goes, like Music > Country), I get this annoying little beep sound like someone hit a high key on a piano.
I only ever hear it when I have my headphones on, thankfully... but it drives me absolutely NUTS when I do have them on!! And I cant find a single thing in Sounds to turn it off. And I wouldn't even begin to know how best to Google it to find an answer that way.
Also, I am aware I can just mute my system sounds (I had it that way before for this very reason) but since Windows Live Messenger is now Skype and does not notify about new emails (nor do they ever plan to apparently), I need my system sounds turned on so I know when I get email.
So, if any one knows how to turn this ever so "charming" notice sound OFF, please tell me. Thank you!
Windows 7 Ultimate Home 64Intel Core Duo @ 3.06GHzNVDIA GeForce GT 130M
HP HDX16 Notebook
Quanta 361B
IDT HD Audio Codec
500GB Seagate
Wacom Intuos4
Norton Internet Security
IE10
Go back into Sounds and under Windows Explorer turn off "Start Navigation". That should do it.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Have you disabled the Start Navigation sound under Sounds?
Windows 10 Pro x64, Windows 8.1 Pro x64, Wind...INTEL i9-7920X LGA 206664 GB (4 X 16 GB) G-Skill V Series DDR4 3200 ...EVGA GTX 1060 SC 3 GB
Windows 10 Pro x64, Windows 8.1 Pro x64, Windows 7 Ultimate x64 SP1,
Gigabyte X299-WU8 F3
64 GB (4 X 16 GB) G-Skill V Series DDR4 3200 Quad Channel
Realtek Onboard ALC1220
2 x Samsung S27E310
Samsung 2 x 970 EVO Plus 500 GB NVMe
1 x 6TB WD 6003FZBX SATA
1 x 6TB WD 60EFRX SATA
12 x 3TB WD 30EFRX SATA
Seasonic X-1050
Thermaltake Armor+
Corsair H80i V2 Liquid AOI Cooler
Logitech G510s
Logitech MX Master 2S
200 Mb/s
ESET NOD32 13.1
EDGE (Dev, Canary, Beta), Chrome
ASUS RT-AC68U router
Malwarebytes 4.0.4
The Start Navigation sound is a click sound. It sounds nothing like hitting a high key on a piano.
Could you also say that it sounds a little bit like a doorbell? This is the Windows sound called "Ding" ("ding.wav"). It's at the top of the list of sounds when you're scrolling through the available sounds for each event.
I love you, lol.
Also, thank you pbcopter and TwoCables!
TwoCables - No, it doesn't sound like a doorbell, its a little "Tink!" sound - which sounds like someone hitting a high key on a piano. Though I guess it would be more correct to say they're half way hitting it. I used to play with my grandparents' piano all the time as a kid and when we half pressed a key, it made a sound like that.
HP HDX16 Notebook
Quanta 361B
IDT HD Audio Codec
500GB Seagate
Wacom Intuos4
IE10
I love you, lol.
You're welcome, but the Start Navigation sound to me sounds like a click, kind of reminiscent of a mouse click. To me, it doesn't sound anything like what you're describing. That's why I didn't think it was the Start Navigation sound.
I think its because of the sound theme mine was set to when I customized the sounds in the first place. I think the default sounds its a click sound, but it changes with other themes.
HP HDX16 Notebook
Quanta 361B
IDT HD Audio Codec
500GB Seagate
Wacom Intuos4
IE10
