HD sound keeping CPU usage at 100%
  1. Posts : 135
    Windows 7 Professional (64 Bit)
    Hi all this might be a hard one to solve but here is the problem...
    when I plug in my speakers into the back of my computer my computer's CPU hits 100% when i have the HD sound enabled.... for the moment i am using AC'97 sound on my Asus P5KPL-CM (its on board sound).
    Thats the only way I can have sound... and I can only use the front plug in port as well.
    If you can solve this problem I will be ever so greatful if you need anymore info on the problem please let me know.
    Cheers
    Gamer1238
    P.S I had this problem when I was running Vista as well.... I don't know if its the motherboard itself or a driver problem
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Cheers
    Gamer1238
    Hi and welcome to sevenforums
    Lets start with info about your computer. make, model, sound chipset.
  3. Posts : 4,573
    1. Current config - AC97, connected at front. CPU usage normal. YES or NO
    2. Current config - AC97, connected at BACK. CPU usage normal. YES or NO
    3. FRONT port wired for HD sound support, HD enabled, speakers connected at front, CPU usage is high or normal?
  4. Posts : 135
    Cheers
    Gamer1238
    Its a custom Built job which I did myself :)
    Motherboard is a Asus P5KPL-CM
    VIA VT1708B 8 -Channel High-Definition Audio CODEC (not sure about chipset how would i find that would that be in Device Manger??)
  5. Posts : 135
    1. Normal at the front yes
    not sure about the other too
  6. Posts : 135
    Normal at the front... when i plug the speakers in the back it switches to HD I think I'm not to sure... I'll try plugging in the speakers in the back and see what happens...
  7. Posts : 135
    also got latest audio driver installed too (VIA Audio Driver V6.0.1.7400 for Windows 32/64bit XP & 32/64bit Vista & 32/64bit Windows 7)
  8. Posts : 135
    here is the CPU-Z info CPU-Z Validator 3.1
  9. Posts : 28,845
    Gamer
    so you know your chipset and have the right driver. can you take a screenshot of the task manager when its pegged at 100%. we need the Process tab
  10. Posts : 135
    zigzag3143 said:
    Gamer
    Ok no problem give me a sec to change it to HD sound and i'll plug in my sound
