System-Wide Audio Stuttering
SabWhipp
6:43 PM
For the last day (since April 1) I've noticed that there is a system-wide audio stutter. It doesn't matter if it's Youtube on Google Chrome or IE or music played via VLC media player, the song will stutter once for just a second then keep going. All the aforementioned software is in its latest state (except maybe VLC but I have no idea why that would cause a system-wide problem). Java and Flash are both as up to date as they can be.
I'm running Win 7 64-bit using Malware Bytes and Microsoft Security Essentials for keeping my laptop clean, both are up to date and have found nothing. I found another thread that seemed similar ( http://www.sevenforums.com/sound-audio/87031-music-stutters.html ) which suggested a “DPC Latency Checker” I tried it, and the checker says that my laptop is fine for streaming so it's not that.
On a whim I also tried a quick defrag and a bit of disk cleanup...just in case; didn't help, but figured I'd throw that in just to sum everything up.
So...Advice?
Addendum: The laptop itself is an HP Pavilion dv4, a check through my drivers says that everything audio related is up to date.
System restore has done nothing, neither has a reinstall of my sound card drivers. A list of all the processes that are normally running can be found lower in the thread for those interested. Disabling all non-Microsoft services has done nothing to fix the problem.
Windows 7 Home Premium 64bitAMD Athlon 64 X2 Dual Core Processor TK-423.00GB RAM (2.75GB Usable)ATI Radeon HD 3200
Acer/Aspire 5517
ATI Radeon HD 3200
Generic PnP display (Laptop monitor)
300GB internal Laptop HDD
External Seagate 1TB HDD
Laptop battery
Laptop case
Laptop fans
One thing I notice, from your System Spec's. You list Win 7 home 64 bit, but only list 3GB of RAM. With only 3GB of RAM you are not getting anything from the 64 bit version. The main thing with the 64 bit version is the ability to access more than 4GB of RAM. Looking at the memory list on the Crucial Memory site, 4GB is Maximum for this model.
You may want to upgrade to max. It won't get you in the 64 bit area, but max memory would be one place to start.
Other potential areas have probably been covered in other posts - this is one of those problems that there is no "one fix". Device drivers for the Video, Sound (use the Acer supplied sound driver, which is the preferred driver). One other trick that helps - sometimes - is to uninstall the sound in the device manager (but NOT the drivers) then restart the PC and when Windows starts it will detect and reinstall the sound. As sound is always on a shared IRQ (Interrupt) with a higher priority device, and subject to interruptions or stuttering, this sometimes puts it on a different IRQ and can have a positive effect.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Thanks for the advice with the ram, I'll upgrade it whenever I get a chance. Laptop came with this OS and this much ram, has been working just fine (well, up until now).
As for your suggestion, wanna make sure I do this right, under the sound and whatever tab of device manager I have a driver for the laptop's webcam, IDT High Definition Audio CODEC, and Intel(R) Display Audio, so I assume you want me to uninstall that last one?
Acer/Aspire 5517
ATI Radeon HD 3200
Laptop battery
Laptop case
Laptop fans
The IDT HD Audio Codec is the PC sound card. That is the one you want to uninstall. RIGHT click on the entry to highlight it and then LEFT click "Uninstall". DO NOT check the box to uninstall the drivers.
No guarantee this will fix it, but a first step.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Okay, so good news, it did as you said it would and installed again right after I restarted; however, there has been no change, Youtube and VLC still stutter once per song/video/insert your favorite media here. Thanks for the help so far Fireberd, any more advice?
Acer/Aspire 5517
ATI Radeon HD 3200
Laptop battery
Laptop case
Laptop fans
What's the CPU usage while it's stuttering? Can you post an elongated screenshot of the processes tab in task manager (showing most/all processes)?
Some other program/application that is running could be causing this. Temporarily stop other programs to see if it makes a difference. Try just the VLC or Windows Media Player with just a song that is already on the PC. Not on line, etc, and see if it does it.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
CPU seems to hang out between 20% and 50% and doesn't really seem to spike when the song stutters. In response to your question about the task list:
As an extra thought: It seems Google Chrome has always had multiple entries in the task manager (closing one will cause tabs open in Chrome to crash and stuff like that). I wonder why it's not just consolidated into one tab, seems it'd make more sense.
Acer/Aspire 5517
ATI Radeon HD 3200
Laptop battery
Laptop case
Laptop fans
hye man, i got the same exact problem, it happened to me acouple of days to, and i tried completely everything, and i still am. but i'll let you know if i ever fix the problem, and it be koo if youd do the same thanks bud -AGEMAN
windows 7 64 bitpentium(R) dual core cpu
dell windows home premium 2009
windows 7 64 bit
20-50% during MP3 playback is too much. Can you post the same screenshot while playing a song?
Do this:
1. Right click on the volume icon in the taskbar.
2. Click "Playback devices".
3. Now under the "Playback" tab, select the option which has a green checkmark on it.
4. Now click "Properties" at bottom right.
5. Now go to "Enhancements" tab.
6. Check mark "Disable all enhancements".
7. Click OK.
Now check the playback.
And Google chrome has so many processes running so that in case of crash of a single tab or extension, only one process out of the so many crashes, and the whole browser doesn't stop working, only the particular tab will stop working and the rest of the browser works. Sorry for my English. I know I couldn't explain it very well.
Nilank, your English is just fine, if it wasn't for your signature I wouldn't know that English wasn't your first language.
Now about the 20-50 thing, when I wrote that I meant that 20-50% is the normal range for CPU usage on my machine. For example, right now with Chrome, Skype, Yahoo Messenger, Peerblock, and all that jazz going my CPU is between 16% and 45% at the high end.
Acer/Aspire 5517
ATI Radeon HD 3200
Laptop battery
Laptop case
Laptop fans
Well, that was good to know, I can't believe, lol :p
Fine, got it. Did you try doing what I suggested in the previous post?
The Disable All Enhancements bit? Yep, did that, still there! Hopefully we're getting somewhere though!
Acer/Aspire 5517
ATI Radeon HD 3200
Laptop battery
Laptop case
Laptop fans
press start key, type "msconfig" hit enter, go to "services", select hide all microsoft services, untill only 3rd party apps and add ons show, then click disable all hit enter, "restart" your computer, twice if you have to, then run your audio program and see if it still stutters. if it doesnt, then your problem is in your add ons and 3rd party apps, your welcome!11
windows 7 64 bit
Looked around my non-Microsoft and all checked out as legitimate services...This is the major confusion point: The audio drivers haven't changed, and I haven't installed/removed any software recently that could have caused the stuttering. My computer just up and decided to have a stuttering problem.
Acer/Aspire 5517
ATI Radeon HD 3200
Laptop battery
Laptop case
Laptop fans
follow the steps i provivded
windows 7 64 bit
Didn't work.
So, VLC is in it's vanilla form, Google Chrome only uses Adblock and Flashblock. IE is vanilla. PC itself only uses Rainmeter. All of the stuff I mentioned was installed long ago. I'm starting to wonder if it's something wrong with the sound card itself (from the laptop getting dropped maybe) and its just starting to manifest now.
So...Anyone else got anything?
Acer/Aspire 5517
ATI Radeon HD 3200
Laptop battery
Laptop case
Laptop fans
Audio Suttering
Hi I had this problem after installing a Sound recorder program. Removing didn't solve the problem. System restore did. I undid the system restore and the stutter game back.
I then looked across various forums to no avail. I then looked at the program more closely. It set the sound output to digital (why?).
I then opened Control Panel and opened up Realtek HD AudioManager.
I turned off the speaker under the tab Digital Output ( just click on the speaker it toggles on or off). This fixed the stuttering and popping. I went back in and also turned off Digital Output (Optical) just in case, as I don't use it.
Hope this helps
Sayar
windows 7 home premium64 bitintel i5 [email protected] lga11568gb Corsair ddr3-1066amd radeon hd 7800 series 2gb ddr5 pcie-3
custom
gigabyte p55a-ud6(c)
Samsung ssd 840 series
WDC 1 TB
2x WDC 2 TB
avast
firefox
Same problem resolved
I realize this is an old thread but after searching online the stuttering problems still are prevalent and there are still many people looking for resolutions. I just did a fresh install of Win 7 Pro and experienced the constant stuttering problem. I traced it to a sound problem but ended up realizing it was a USB problem regarding my USB headset and the VIA audio Mixer. I removed the USB controllers relating to the headset and the VIA audio mixer in the Hardware Manager and when Windows found them again a repair was performed automatically which in turn fixed all the stuttering problems. Now everything is smooth as butter. I am able to redirect the VIA sound from the mixer to the USB headset as well. If you have stuttering problems on Windows 7 you might want to look at the USB controllers.
Regards
Windows 7 Pro x64i7-3770K24 gig KingstonASUS GTX770
Homebrew
Windows 7 Pro x64
i7-3770K
GA-Z77X-UD3H
24 gig Kingston
ASUS GTX770
Kingston 120gig SSD x 3
