Realtek HD Audio Manager: Device has been plugged/unplugged issue
desktop
11:09 PM
Michigan
I have the latest Realtek HD Audio Manager installed, but I have this rather wierd issue. Whenever I'm watching any video (music or otherwise) the Audio Manager pops up and keeps saying I plugged and then unplugged a device from the audio jack. The manager keeps saying it's "Headphones", but I haven't done anything.
It doesn't matter how many times I click "OK" it just keeps coming back, saying "a device has been plugged/unplugged" and I have to shut down the window with the video source to get it to stop. I have uninstalled the audio manager then re-installed the latest version form the manufacturer's website and I've also disabled the front IO panel detection thinking it might be something screwed up there, but the behavior continues.
Any ideas and/or suggestions on how to fix this weird behavior would be appreciated.
Thanks.
Windows 7 Home PremiumIntel Q6600 SLACR (2.7GHz)8GB G.SKILL PC6400ASUS EN9600GSO GeForce 9600 GSO 512MB
Gigabyte P35-DS4 (Rev 2.1)
8GB G.SKILL PC6400
LG W2252TQ 22" Widescreen
2 x SeaGate Barracuda SATA (250GB, 320GB)
PCP&C Silencer 610
Ultra m998
ThermalRight Ultra 120E
Logitech K360
Logitech Performance MX
Also, I went into the HD settings, clicked the little "i" icon and unchecked "Display icon in notification area". This has not helped, either. The manager still pops up whenever I'm watching something and either says I've plugged/unplugged headphones or some speaker (it's usually a rear one).
8GB G.SKILL PC6400
PCP&C Silencer 610
Ultra m998
Logitech K360
Try reseating and checking your speaker connections. If you are not using headphones you could also disable the front panel connection.
Windows 10 Pro X64Intel(R) Core(TM) i5-3570K CPU OC@ 4.5GHZ Turbo8.00 GB DDR3 1600MhzMSI Gaming X GTX 1070
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Realtek High Definition
Dell S23O9W, HP L1710
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
MSI DS100 Interceptor
50 down and 5 up
Chrome, IE 11
Logitech X-620 Speakers
I have started and restarted numerous times and checked and double checked speaker connections. Everything there seems fine. I already disabled the front panel detection in the HD manager. Unless you mean to disable it somewhere else?
8GB G.SKILL PC6400
PCP&C Silencer 610
Ultra m998
Logitech K360
Could be a flakey front panel headphone jack, the cable that connects the front panel headphone/mic jacks to the motherboard, etc. Reseat the audio cable connector (unplug then plug back in) at the motherboard and see if that helps. If not, remove the cable and see if it still reports the headphone jack problem. If it still does it with the cable disconnected most likely a problem in the chip or motherboard, but at least you can isolate to where the problem is.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I'll try that, fireberd. Thanks.
8GB G.SKILL PC6400
PCP&C Silencer 610
Ultra m998
Logitech K360
You can buy a separate front panel I/O assembly and use that instead of the one built into the PC case. Less expensive.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I unplugged the front audio cable from the MO and it's not happening anymore. I can just leave that unplugged, since I never use the front audio jack for anything anyway.
Thanks!
8GB G.SKILL PC6400
PCP&C Silencer 610
Ultra m998
Logitech K360
Hmm...I don't have any sound on Netflix. That's weird. I have sound everywhere else.
8GB G.SKILL PC6400
PCP&C Silencer 610
Ultra m998
Logitech K360
That is a separate problem and nothing to do with the flakey jack.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
