Windows 7: can't change default sound device
04 Apr 2013   #1
Windows 7 x64
Hi, I'm on Windows 7. When I go to Sounds and try to make my headphones Default device and not just default communications device, nothing happens. The headphones are connected by jack so the driver continues to be IDT High Definition Audio CODEC. Now, I can hear most sounds on my headphones, but when I try to use a communication device (Mumble), I can't hear anything from that application. Driver is up to date. Problems started when I opened Teamspeak and the sound for the game I was playing at the same time (SWTOR), went to laptop speakers instead of staying with headphones. I tried fixing that by playing with device settings in Sound, reinstalling Mumble, and still not working. Tried doing troubleshooting, but it shows as everything works, even though when I do sound tests for my headphones, the test sounds don't work but the intensity bar moves. No sound is muted in the mixer.
Similar help and support threads for2: can't change default sound device
Solved default sound device is disable Sound & Audio
How to set default sound playback device Sound & Audio
Cannot change the default playback device Sound & Audio
How can i change the default device removal policy? Hardware & Devices
change default device sound with a bat file? Sound & Audio
Change default sound device? Media Center
Changing default Sound Device Sound & Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
