Windows 7 Forums Search
Windows 7 - Surround Sound + Realtek
10-11-2009   #1
Windows 7 Ultimate
OK So!
Ive tried EVERYTHING even bought a new set of speakers thought the others were broken. I am running windows 7 ultimate and i have tried every realtek driver known to man. And I still can't get my surround sound to work I haven't re-assigned the jacks cause i am not to sure how to do that and dont want to have any sound..
Can anyone get my surround sound to work?
10-11-2009   #2
It will help others to help you to know your entire system specs. You can fill in your specs in your user cp located at the top of the page. Then suggestions of which Reltek drivers to try, possibly a bios update as well as chipset drivers. Thanks and welcome to sevenforums.
10-11-2009   #3
WCP ONLY
MM
why dont you tell us about your computer. make, model, ram, audio.
thanks
ken
10-11-2009   #4
Windows 7 Ultimate
Done! I filled it out
10-11-2009   #5
ECS Web Site This is the driver section from your MB site including the Realtek HD Audio driver 2.25 I assume you have tried this one? Correct? The site also requests a version # for your MB which might change some of the drivers or possibly a bios update. Lets start from here. ( thanks for filing out your specs)
10-11-2009   #6
Windows 7 Ultimate
I don't want to do a bios update and break my computer. I tried those drivers already
10-11-2009   #7
Windows 7 Ultimate
OK so I reinstalled the sound drivers and set it to 5.1 and only 2 speakers work. I"m asuming I need to re asign jacks
10-11-2009   #8
Here is a whole thread on this issue with a lot of suggestions you might want to try .Realtek HD Changing Jack output reassignments ( FIX )
10-11-2009   #9
Windows 7 Ultimate
I dont want to break anything i need step by steop
10-12-2009   #10
Windows 7 Ultimate
Anymore updates?
Anymore updates on this issue?
 Surround Sound + Realtek problems?
Similar Threads for: Surround Sound + Realtek
Windows 7 5.1 surround problems (realtek) Sound & Audio
Realtek Surround issues Sound & Audio
?Headphones Realtek Surround Problem? Drivers
problem with realtek configuration and surround sound Sound & Audio
Realtek surround problems in 7 Sound & Audio
