Windows 7: Any way to disable the system tray volume control?
11 Oct 2009   #1
I'm running a Creative Xtreme Music card and it comes with its own volume control for the tray. I'd like to disable the default windows volume since I'll never use it, anyone know if there's a way? Not finding it like you would in XP.
11 Oct 2009   #2
Windows 7 Ultimate x64 + x86 + Windows 8 x64
Newport, South Wales, UK
Try Here ...
Control Panel -All Control Panel Items - Notification Area Icons - turn system icons on or off
11 Oct 2009   #3
whs
Florida in winter, Black Forest/Germany
If you just want it out of the notification area, you can also right click on the taskbar > Properties > Customize > Hide Icon > Apply > etc.
12 Oct 2009   #4
I'd prefer to turn it off entirely to stop wasting the ram.
12 Oct 2009   #5
ultimate 64 sp1
the windows volume control can do things that the creative one cannot, and doesn't waste any ram at all.
with the windows volume control, you can control the volume of each app - so if you were, as an extreme example, playing a game at the same time as listening to winamp, talking to someone on msn and watching a video in kmp, you can have control of each of the programs' volume levels...could be useful, you may want to keep it.
but of course, it's up to you! and if you do want to turn it off, try Barman58's tip.
12 Oct 2009   #6
whs
Quote   Quote: Originally Posted by Kuragari View Post
What RAM?
 Any way to disable the system tray volume control? problems?
Similar help and support threads for: Any way to disable the system tray volume control?
Where is Volume Control ? Mic Enable & Disable Sound & Audio
Solved no volume in system tray General Discussion
Solved How do programs control system tray icons ? Performance & Maintenance
Enable applications to control system volume Sound & Audio
System Tray- Volume grayed out Sound & Audio
