Volume Control There are no active mixer devices available error
  1. Posts : 532
    Windows 8.1 64 bit
    Alright so I just recently installed Windows XP on an old Laptop . It seems to appear my sound icon is missing every time I try to access volume control it gives me this display error
    http://realtimeissues.files.wordpres...umecontrol.jpg
    I tired to do the service. msc , didn't work.
    Did you install the correct XP sound drivers for the PC? Also before the sound drivers, any motherboard chipset drivers.
  3. Posts : 532
    Windows 8.1 64 bit
    All I did was Install XP and no Volume control came with it.
  4. Posts : 6,830
    Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
    Raiden92
    What is the model of the laptop in question ?
  5. Posts : 532
    Windows 8.1 64 bit
    VistaKing said:
    Raiden92
    How do you check what model again would it be located under the laptop?
  6. Posts : 6,830
    Open up a command prompt . Click on the button type CMD , right click and choose Run as administrator . Input the commands below
    wmic csproduct get vendor,name,identifyingnumber
  7. Posts : 532
    Windows 8.1 64 bit
    Model Number: emachines M5405
  8. Posts : 532
    Windows 8.1 64 bit
    Should I just download realtek HD Audio . This has always been a way to fix it . Every time I bumped into a problem like this. I am thinking of giving it a shot.
  9. Posts : 6,830
    Try this
    AC'97 Audio Codecs
    No code has to be inserted here.
  10. Posts : 532
    Windows 8.1 64 bit
    VistaKing said:
    Try this
    AC'97 Audio Codecs
    Is that different then realtek?
