problem on my PC with no sound, with OS Windows 7 Ultimate PT-pt
  1. Posts : 4
    Dears,
    I have a problem on my PC with no sound, with OS Windows 7 Ultimate PT-pt.
    I do not know why because I no longer have sound.
    I've tried connecting other columns and nothing works.
    The cable with the "jack" is well connected, as well as the USB plug.
    I note that reproduces the sound, because you see the scale of sound to move as the peaks of the sound, but the column does not play, not even system sounds.
    I am sending a report containing information about the motherboard and the sound card of my computer so that they can assist me in solving:
    Motherboard:
    CPU Type QuadCore Intel Core i7-950, 3200 MHz (24 x 133)
    Motherboard Name Gigabyte GA-X58A-UD5 v2 (1 PCI, 2 PCI-E x1, 4 PCI-E x16, 6 DDR3 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
    Motherboard Chipset Intel X58 Tylersburg, Intel Nehalem
    System Memory 12288 MB (DDR3-1333 DDR3 SDRAM)
    DIMM1: Corsair XMS3 CMX6GX3M3A1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz)
    DIMM2: Corsair XMS3 CMX6GX3M3A1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz)
    DIMM3: Corsair XMS3 CMX6GX3M3A1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz)
    DIMM4: Corsair XMS3 CMX6GX3M3A1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz)
    DIMM5: Corsair XMS3 CMX6GX3M3A1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz)
    DIMM6: Corsair XMS3 CMX6GX3M3A1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz)
    Type Award Modular BIOS (03/07/11)
    Multimedia:
    Sound Adapter nVIDIA HDMI / DP @ nVIDIA GF108 - High Definition Audio Controller
    Sound Adapter Realtek ALC889 @ Intel 82801JB ICH10 - High Definition Audio Controller
    The drivers I have installed R2.71, were taken away to Windows 7 64bit:
    Realtek
    I await your information which I thank you.
    Hugs, Daniel Dias.
  2. Posts : 51,477
    Windows 11 Workstation x64
    English only is this forum, if you need help please post a translation.
      My Computers
  3. Posts : 4
    Hi "z3r010"
    Thanks, my friend.
    Hugs. Daniel Dias
  4. Posts : 1,269
    Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
    Under SOUND | Playback tab (the first one)
    What's listed for the output with a check mark next to it? [the check means system default]
    Speakers
    Default Device
    Is likely what you want... if it isn't highlight it and select default.
    If that is correct I'd go into Properties there and look for disabled sound and fix it.
    Also, does you keyboard have a mute button, have seen that do it.
  5. Posts : 4
    Hello "FALADU"
    Is solved. Thanks for the help.
    Hugs.
