No Sound, Windows 7 Issues. Require help asap!
  1. Posts : 22
    Windows 7 Ultimate 32-bit (6.1, Build 7600)
    Hello everyone!
    I accidentally pressed something and this is the second time i'm writing this damn thing.
    Anyway, I have no sound coming out of my computer.
    Q/A
    Q: Have you installed the latest driver, suitable for your soundcard?
    A: Yes, several times.
    Q: Have you checked every settings that could affect this issue?
    A: Yes, every setting that i have found, trough out searching the internet for a week, i still have not found the solution.
    Q: Have you tried reinstalling the OS?
    A: Yes, again several times.
    Q: Have you installed codecs, checked the latest updates from Windows Update?
    A: Yes, i have found some updates, installed them properly, but still. Nothing has worked.
    Q: Have you installed the Daniel_K driver for windows 7?
    A: Yes, not helping.
    Q: Have you tried to run the driver in your previous OS compatibility?
    A: Yeeeeeeeees.
    Information of my computer, according to Dxdiag:
    OS: Windows 7 Ultimate 32-bit (6.1, Build 7600)
    Motherboard: Asus P5PL2
    Processor: Intel(R) Pentium(R) 4 CPU 3.2GHz (2 CPUs), ~3.2GHz
    Memory: 1024MB RAM
    Video Card: nVidia GeForce 9600 GT
    Sound Card: SB Audigy 2 ZS (WDM)
    Is it something i can't figure out? or is it something wrong about Microsoft, Compatibility issue maybe or what? Please. hellllllp
  2. Posts : 11,840
    64-bit Windows 8.1 Pro
    Have you checked the sound mixer and make sure that you have speakers as the default playback device...
  3. Posts : 22
    Yes, i have... i actually tried to attach few pictures if it would help, donno where did they go? :S
    Wait, what do u mean by Sound Mixer? How do i check this?
  4. Posts : 11,840
    right click on you speaker icon in the task bar.. click on playback devices, choose speakers.... for some reason the default device is headphones...
  5. Posts : 22
    The default is the speakers, u'd think i'd check that after a week of suffering with no sound
  6. Posts : 11,840
    Do you show any meter movement while playing an mp3?
  7. Posts : 22
    Yes, if i play something, the meter is going up and down, if i do a test it is going up and down. I'm so frustrated :/
  8. Posts : 11,840
    back in the mixer... under speaker, go to the advanced tab, click on test speakers... do you get any sound?
  9. Posts : 22
    Nope, nothing :S Did you get the pictures i attached? i mean can u see them somewhere? or did i fail.
  10. Posts : 11,840
    have you tried disabling the SB card and see if you get any sound from the onboard sound device?
